It was a suggestion from a fellow on Htt, to get me started in the absence of any available maps for my new cams. I guess it ensures that the VE tables don't max out. Just until I can schedule the tune
or maybe it is just the be sure that you don't run too lean ?
I wonder if there is changes to do on a map when compression ration is raised ?
Asking this cause i get a canned map from dynojet for the 57h, but 'ive raised the CR a little...
I have been running autotune sessions on mine after cams, heads and compression bump and the bike is running really, really well!
I used a 57h base map from Fuel Moto and have only done three autotune runs so far, capping the values as they are coming in over the 127.5 limit. I'll keep doing this with more autotune sessions until it's properly dialled in.
I am extremely happy with this setup right now - the bike just keeps on pulling with no end in sight. It gets from 60-90 much quicker and overtaking is effortless. No popping on decel either.
I will get it dyno'ed in the future, but will buy a larger throttle body first as right now I have the stock 46mm unit and I know that can't flow all the air that the heads can handle.
Well, I left it at 103" (I might do one of the bolt in 110 kits next year though)
Heads got a "Pro Port" job from Fastlane Head Work: http://fastlaneheadwork.co.uk
Andrews 57h cams
Lifters ended up being Gaterman GP1023 ( I had Comp Cams 850-1s originally, but one was ticking away so I swapped to the Gatermans as I found some new old stock ones.)
Pushrods are S&S Quickees
0.030" Cometic MLS head gaskets
Static compression looks to be 9.90:1
Corrected compression is 9.2:1
CCP 190.6 @ sea level
Other stuff - the air cleaner is a DK Customs Outlaw 636v and the pipe is a D&D BobCat.
