Low rider handlebars
I want to change my handlebars on the low rider. Either want chrome versions that are the same, or switch to slightly more buckhorn style (rotate wrist a bit).
However, I want to do internal wiring as well. I have been told the Harley chrome bars are no good to drill. Apparently they use the stainless bars and just chrome them - and since chrome doesn't adhere well to stainless, it chips away once drilled.
I can't seem to find any similar chrome bars after market. I woudl like to keep the same clamp because of the idiot lights.
Anyone found anything similar in chrome? Thanks.
http://www.harley-davidson.com/gma/g...bmLocale=en_US
Do you have experience drilling the Harley bars?
An independant service shop told me the Harley bars are not good to be drilled for internal wiring. As I mentioned earlier, the harley bars are made of stainless, and then chromed. Apparently the chrome adhesion to stainless is so poor that where you drill them, the chrome will flake off and continue to deterioriate.
For this reason, i was hoping to find some after market bars (either chrome on cold steel, or pre-drilled).
Chrome-plated handlebars are designed to be exact replacements for the Original Equipment stainless steel handlebars."
If they were the same material, why would they even mention stainless? Now I'm not 100% sure about that,but they're only $38.71 at Zanotti's. Worth a try.
The only bars that I have ever had chip (when drilling) were a set of Flanders beach bars, and they were not chromed stainless... just a bad chrome plating job on mild steel tube.
The stainless bars are a little rough on the drill bits. The chrome versions are much easier to drill.
Incidentally, I did to my Low Rider what you want to do... just get a little more rise and pullback than what the stockers give, and to run the wires inside. I used a set of bars (stainless) off a 2001 Superglide. They are about an inch higher with about two more inches of pullback.
Get whatever bars you want and drill some holes. Don't worry about it so much... it's all good.
I also found the Superglide bars to be very comfortable. FOr me it has to do with wrist rotation. The stock bars keep my hands "flat" and that causes some discomfort on long rides.
But with the SG bars, did you have to run extensions on your internal wiring to fit, or was there enough slack in the wiring harness? If you did extensions, did you splice (solder) or use a "connector" extension kit?
Thanks.... Warren
I've drilled lot's of Harley stock bars... stainless and chrome. They are different. The chrome bars are mild steel, they are NOT chromed stainless.
Thanks for this info - I'm happy to hear the guy was wrong about the Harley chrome bars.
Thanks.... Warren
I've never used an extension kit... too expensive, and there's no guarantee that the length you end up with will be correct. Too much wire to hide can be worse than not enough wire.
