Dynas with ABS -- transmission fluid change?
Old Apr 16, 2016 | 10:51 PM
Fishrrman's Avatar
Fishrrman
Default Dynas with ABS -- transmission fluid change?
This is for Dyna owners that also have ABS:
When it's time to change the transmission fluid, can the ABS unit be "un-bolted" from the frame and moved aside, for easier access to the fill plug/dipstick?
Looks like it would be pretty tough to refill or check the fluid level with the ABS module in the way...
Old Apr 17, 2016 | 01:12 AM
Helmsy67's Avatar
Helmsy67
You can take the plastic cover off off the ABS module and get to the dipstick. I use a T-handle Allen wrench. 3/8 if I recall.
Old Apr 17, 2016 | 09:39 AM
iceman4160's Avatar
iceman4160
If you remove the ABS cover just make sure it you get back in place properly, or it might end up in between your frame and exhaust.
Old Apr 17, 2016 | 01:12 PM
Maxxsmart's Avatar
Maxxsmart
I use a socket, and a u-joint to get the plug out after I snap the cover of the ABS module. Go get a cheap transmission funnel from an auto parts store, and that will keep the filling nice and clean. Checking the level does suck, but it's do-able.
HD says their Speed Check dip stick says it will not fit with BAS< but I want to give it a try... There's a little room there.
http://www.harley-davidson.com/store...-10-3710308--1
Old Apr 17, 2016 | 11:13 PM
Andy02's Avatar
Andy02
The ABS unit can be unbolted but it doesn't move far because of the hard lines. I am not sure if it would be far enough to get to the trans fill plug any easier. I had mine unbolted for a different reason.
Old Apr 17, 2016 | 11:35 PM
JustOneDean's Avatar
JustOneDean
I just take the plastic cover off and use a ball-end allen to get to the dipstick.
Joe from So Cal
Nov 15, 2020 10:39 AM
AbeVigoda
May 21, 2018 11:03 PM
melvinrdm
General Topics/Tech Tips
Apr 19, 2016 07:43 AM
1HDRIO
Harley Davidson Videos
Aug 7, 2014 08:28 AM
HDV-GLIDE
Aug 2, 2008 07:48 PM
