Clicking sound after cam install.
Old Aug 18, 2016 | 02:40 AM
re-volt's Avatar
re-volt
6th Gear
I am no expert Frederic, but I think the only way is to re open the engine and make sure of the clearance. One thing I saw on the installation instructions that came with the cams, to grind the valves slightly if the proper clearance is not achieved, which is I was against so I went with the adjustable pushrods, but still it may be the case, looking into taking the machine now to a Dyno and figure this out and get done with it.
Old Nov 15, 2020 | 04:09 PM
Sergio Ramirez's Avatar
Sergio Ramirez
Stage I
Default Update
Originally Posted by re-volt
Thank you tincup for advice, I will try to take another spin again tomorrow and see how things go. I talked to the workshop today and their answer was they think it might be pinging at this range, and should be tuned for that particular behavior. Let's just hope if this is the case that the fp3 can handle it properly.
hey man did you ever figure out what the problem was? I got the same kind of noise, I thought that one of the push rods was rubbing against the covers but I checked and that wasn't the case, then I put the fp3 on auto tune and I noticed that the noise got worse on 3rd and it turned of on me several times. I managed to get it back home and now wondering if I should go open my cam case and check I anything is rubbing. Let me know what you found out about your problem.
Old Nov 15, 2020 | 09:59 PM
mcwarren's Avatar
mcwarren
http://rockerlockers.com/
Old Nov 15, 2020 | 10:01 PM
mcwarren's Avatar
mcwarren
Old Nov 15, 2020 | 10:02 PM
ROCKOUT Rocker Products
Sponsor
Have a look around my website, might be just what you need
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old Nov 16, 2020 | 07:51 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
In all honesty 4th gear and 2,000 rpms does not go well together, I'd be downshifting to 3rd or 2nd to get better power and less punishing to the engine to get up to speed. To slow of engine speed for 4th gear.
Boy do I feel like a dolt responding to a 4 year old thread, hope the OP figured it out.
phopnick
Oct 22, 2016 02:37 PM
irydasteelhorse
Oct 19, 2016 07:14 PM
Hate Work
Jul 14, 2015 06:46 PM
pauletich
Exhaust System Topics
Jul 2, 2008 07:53 AM
tdaffner
Feb 26, 2008 10:10 PM
