Fxdb top cylinder head removal
Old Oct 12, 2016 | 03:27 PM
gmorgens's Avatar
gmorgens
Default Fxdb top cylinder head removal
im not an engine guy so please bear with me. Im trying to remove my front top cylinder head so I can drill out and replace the exhaust port stud.
I do have a service manual. But it goes into more depth removal than prob what I need. I have removed the gas tank and air induction unit and top rocker box cover. My wuestion is it says the engine should be top dead center before proceeding to take pressure off the valves and pushrods? Etc.
but I am trying to accomplish this by turning the rear wheel. -an nothing inside is moving up and down. No valves etc.
am I missing a step in there? I dont want to mess anything up which Is why I havent gone further.
Thanks!
Old Oct 12, 2016 | 03:30 PM
Smokey Stover's Avatar
Smokey Stover
Put it in gear, 6th is easiest.
Old Oct 12, 2016 | 03:33 PM
gmorgens's Avatar
gmorgens
I had it in 6th. But it only moves back like 8". No valves move or snything.
Old Oct 12, 2016 | 03:37 PM
Smokey Stover
I have a bad back so I lay on the floor and use my foot. Pull the other plug out, Your probably on compression stroke of the rear cyl.
Old Oct 12, 2016 | 03:53 PM
gmorgens's Avatar
gmorgens
That would prob make sense.ill give it a shot. I figure something somewhere is locked up
Old Oct 14, 2016 | 01:50 PM
gmorgens's Avatar
gmorgens
still nothing moving.
Old Oct 14, 2016 | 04:34 PM
Suede Blue Man's Avatar
Suede Blue Man
Remove both spark plugs, put it in 6th, should be fairly easy to rotate the rear wheel.
Old Oct 15, 2016 | 04:01 AM
JustOneDean's Avatar
JustOneDean
Do you mean there's a lot of resistance when you're rotating the wheel? If so, that's normal. It's easiest in top gear with the spark plugs removed, but it can still be strenuous. If you mean the wheel's spinning but the engine isn't, then you're in neutral.
Make sure, before you break loose the rocker plate bolts, that that cylinder is in top dead center compression. If it's on top dead center overlap, there's still pressure on the valvetrain. The tappets (lifters) also need to have bled down. If you can spin the pushrods by grabbing them with your thumb and index finger (and a paper towel, given how oily they probably are), you're in good shape.
Old Oct 15, 2016 | 06:35 AM
gmorgens's Avatar
gmorgens
How dumb am I? It was alot of resistance. Smh. I was like man seriously. Thanks guys.
Old Oct 15, 2016 | 03:31 PM
JustOneDean
Heh, no worries, man. When you're doing something new on a bike and you feel that much pressure, it's real easy to worry you're gonna break something. But as long as the engine's assembled correctly, turning it over by hand won't hurt anything, it'll just tire you out.
Softail332
Engine Mechanical Topics
Sep 4, 2017 09:42 AM
98glider
Ironhead
Nov 18, 2012 05:32 PM
cliffside tattoos
Ironhead
Sep 21, 2012 09:30 PM
1rickr
Ironhead
Aug 5, 2012 06:37 PM
85Sporty
Ironhead
Jul 29, 2012 07:13 PM
