Not a "Build Thread," just my motor...
Old May 23, 2017 | 08:26 PM
  #71
multihdrdr's Avatar
multihdrdr
Originally Posted by cggorman
I'm not well versed on the cam drive specifics but the inner always wears faster than the outer. Not to this degree, but still...
A few thoughts unrelated to engine-specific junk.
-Spring manufacturing tolerance (more than nominal on inner, less than nominal on outer)
-Shoe material tolerance.
-Burrs on inner chain.
-Tensioners were not replaced in sets.
"Tensioners were not replaced in sets"
Specifically I wondering about this. How many miles have you put on it yourself
Old May 23, 2017 | 08:31 PM
  #72
ROCKOUT Rocker Products
Sponsor
Awesome thread, thanks!
For ROCKOUT information & purchasing please click the LINKS below... For all Twin Cams and Evo Big Twins & Sporsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old May 23, 2017 | 08:36 PM
  #73
F86's Avatar
F86
You'll like it better soon... There's a set of your product sitting on my bench!
Old May 23, 2017 | 08:39 PM
  #74
F86's Avatar
F86
Only around 3000... And I would be surprised if the outer had been changed in the past, considering the mileage. Although, looking through the pile of receipts I have, the original build used SE211 cams which were changed out for Andrews TW60s a year later... I suppose one tensioner could have been changed then...
Old May 23, 2017 | 08:41 PM
  #75
F86's Avatar
F86
Here are some more,
- heavy valve spring popping the tensioner off the chain as the lifter rolls off the lobes.
- Excessive heat from a poor tune.
- sprockets on cams not running true to axis..
- stretch spots in chain.
Hmmm... I do have heavy valve springs. I wonder whether the change to hydraulic tensioners would reduce that effect?
Any way to test the chains for integrity?
Old May 23, 2017 | 08:44 PM
  #76
F86's Avatar
F86
I don't know if it was my imagination, but the inner unit did seem much harder to open than the outer one did...
Old May 23, 2017 | 09:06 PM
  #77
cggorman's Avatar
cggorman
Hey, a question for those in the know that are watching...
The recent engine builds all show guys buying specialized holders for their runout measurements. Any reason crank runout can't be measured with conventional dial indicator holders?
Old May 23, 2017 | 09:12 PM
  #78
F86's Avatar
F86
I'm sure you could do it with a different holder. I was going to borrow one from work that basically has a swivel arm that can be bolted to anything. I think the only reason I ended up buying one was that I told myself at the beginning of this project that I wouldn't skimp on special tools, for the simple reason that I didn't want to be distracted/frustrated trying to make things work if there was a simpler solution. I figured I'd find enough frustration just figuring out how to do the job correctly without also having to mickey-mouse tools!
But in hindsight, I think this particular step would have been pretty simple with a universal holder of some sort.
Old May 23, 2017 | 09:13 PM
  #79
cvaria's Avatar
cvaria
https://www.hdforums.com/forum/engin...l#post16153549
Old May 23, 2017 | 09:28 PM
  #80
cggorman's Avatar
cggorman
Thanks guys. I figured as much but being uneducated I hated to assume.
I have a chest full of measuring equipment for engine building but this is my first V-Twin. I'll be opening her up in a couple weeks...either to replace just tensioner shoes or the entire contents of the cam chest...depending on what I find.
