Forward Controls
Old Jun 23, 2017 | 02:08 AM
Smogbob's Avatar
Smogbob
Originally Posted by FXDL32966
the nut, item 11, is all the way in, will not shorten. I am leaning towards relocating the brake bracket back 2" and then shortening the rod at the peddle end to match. I'm short so need to improvise where I can. this forum is really helping me out, so thanks.
Not sure we are understanding each other here, lets try again, if you have a nut on the rear end of the brake rod, its called a Jam nut, with two spanners you can loosen the jam nut and unwind the brake rod at least an inch out of the rear cylinder, obviously you have to unhook it front the brake pedal first, hope this helps, or maybe you have a completly different brake rod that I am thinking of, if that is the case you can easily get an adjustable brake rod and this will bring your rear brake forward at least 2 inches.
Old Jun 23, 2017 | 04:44 AM
FXDL32966's Avatar
FXDL32966
6th Gear
Thanks, but I'm not opting for a seat. Going to cut the rod back.
Old Jun 23, 2017 | 06:13 AM
Smogbob's Avatar
Smogbob
If you make the rod shorter the brake pedal will be further away from your foot.
Old Jun 23, 2017 | 06:49 AM
STRES's Avatar
STRES
Just install mid controls if you are that short
Old Jun 23, 2017 | 07:49 AM
SASK_RT's Avatar
SASK_RT
As mentioned above, shortening the rod will put the brake farther away from you.
What you need to do is disconnect the rod from the pedal then loosen the jam nut at the back. This will allow you to rotate the rod exposing more threads. As you expose more threads it makes the rod longer. And because it mounts to the bottom of the pedal, this rotate the top of the pedal back towards you.
Give this a try before cutting or replacing anything...There should be lots of adjustment.
Old Jun 23, 2017 | 01:12 PM
STRES's Avatar
STRES
Or be stubborn and create a new thread and ignore the advise
thoner7
Jun 21, 2016 04:34 PM
ss243b
Aug 22, 2014 07:08 PM
clap
Aug 28, 2013 10:30 PM
dauspainting
Apr 18, 2008 11:01 PM
hounds
May 30, 2007 01:24 PM
