valvetrain clatter at startup
Old Aug 21, 2017 | 02:54 PM
fugawi's Avatar
fugawi
Originally Posted by TUCCI
I had lifter bleed down real bad on my 96" Road King when I was using synthetic that went away after I started using regular conventional. I even replaced the stock pushrods with SE adjustable tightened up pretty tight to no avail. It took 3-400 miles before it went away. I came to the conclusion Vtwins don't like synthetic oil.....you'll need to make that determination on your own.
I was thinking about this also. and I'm close to my oil change. this maybe a solution that could be a less expensive alternative as the valve train is fine except at initial start.
MacKo2000
Engine Mechanical Topics
Apr 27, 2014 10:54 AM
CBassard
EVO
Feb 10, 2014 05:43 AM
tom071200c
Dec 29, 2012 03:45 PM
masterblaster
Oct 15, 2010 01:42 PM
rah002
Oil Archive (no new posts)
Feb 6, 2007 02:58 AM
