compensator problems
Old Jul 22, 2018 | 11:59 AM
TwiZted Biker's Avatar
TwiZted Biker
Originally Posted by Wheelup
Eliminate the compositor totally. Engine sprocket, and forget the problems. No clunking, noise or perts to wear each other out. I've never had a problem on any of my builds. Tens of thousands of miles on high horsepower bikes. Zero issues.
Only issue running without one on these high ratio bikes today is a higher risk of scissoring the crank. Comp is a buffer, take that out and something else takes the load. I've trashed big inch shovel flywheels running direct drive with no comps.
Old Jul 22, 2018 | 06:07 PM
misfitJason's Avatar
misfitJason
So all of the guys with Baker's.. How many have 40K on them? Also are the motors built?
I have approximately 15k on mine with a built motor
Old Jul 22, 2018 | 09:13 PM
TexasScooterTrash's Avatar
TexasScooterTrash
I have over 98,000 miles on my 07 Dyna with the original compensator. No problems with it . . . ever. Around 37,000 the stator went out and I replaced it. When I pulled the primary cover off the chain was tight with no play at all. Not good. Buttoned up the repair with a new stator and Hayden adjuster.
Old Jul 23, 2018 | 06:28 AM
Notgrownup's Avatar
Notgrownup
Only about 5000 on my Baker compensator...
Old Jul 23, 2018 | 10:16 AM
slippin_jimmy's Avatar
slippin_jimmy
When going with a Baker compensator, will it work with stock (06B) rotor and stator? I changed out both recently.
Old Jul 23, 2018 | 12:50 PM
Notgrownup's Avatar
Notgrownup
I didn’t change those on mine, they are new but stock.
keno
May 30, 2015 08:10 AM
wscott
Mar 24, 2015 12:53 PM
jackhis
Oct 20, 2013 09:48 AM
Screamin'Bagger
May 9, 2013 03:46 PM
Challenger
Feb 16, 2012 06:12 PM
