Clunking noise when slowing down.
Old Sep 25, 2018 | 10:42 PM
Feralyouth's Avatar
Feralyouth
6th Gear
Default Clunking noise when slowing down.
So I recently purchased an 03 dyna super glide tsport fxdxt. Sat for awhile which was clear when I had to clean the idle jet... anyways bike has been running great. Today I jump on her and ride a few miles to get food. I finish and get back on it’s all good... all of a sudden I pull en the clutch and I here a clinching sound as I slow down. So naturally next time I’m coming to a stop I slap her into neutral and same issue. Noticed recently the shifting can be load, but then again I’m new to Harley’s so i don’t know. Help!
Old Sep 25, 2018 | 10:48 PM
Feralyouth's Avatar
Feralyouth
6th Gear
Old Sep 26, 2018 | 01:02 AM
mmesa005's Avatar
mmesa005
I would check the clutch and primary chain adjustments. Also, check your fluid levels in the transmission and primary. No leaks under the bike?
More info here: https://www.hdforums.com/how-tos/a/h...c-guide-413964
Old Sep 26, 2018 | 01:25 AM
Feralyouth's Avatar
Feralyouth
6th Gear
No leaks that I have seen... checked the oil while a little warm and it’s good but dirty... just for clearification I noticed the shifting was loud and hard, even in gear and reducing throttle just a bit will also cause the cluncking to start. It’s hard to tell when excelerating if the problem is occurring or not, but I think it might be. Clutch and neutral don’t help reduce it when slowing down.
Old Sep 26, 2018 | 01:30 AM
mmesa005's Avatar
mmesa005
Sounds like an oil change may be due along with the clutch and primary chain adjustment?
Old Sep 26, 2018 | 07:55 AM
rauchman's Avatar
rauchman
Common clunking fix.....
Try correctly torqueing the bolts that hold the tank on. IIRC, it's 17-20 ft/lbs. Verify with the shop manual.
Old Sep 26, 2018 | 08:02 AM
joe40x's Avatar
joe40x
And check your fall away
Old Sep 26, 2018 | 11:49 AM
Feralyouth's Avatar
Feralyouth
6th Gear
Default Good news everyone!!!
So I really appreciate the comments and help! Spent all night looking things up. I came across a video of a guy I watch quiet often (link below). So a common issue with Dynas is loose bults on the rear belt pulley attached to the wheel. Sure enough the were all loose and some were scrapping. So on My days off I’m going to pull them all out and put lock tight on them. Also going to check the primary chain tensioner and change oil.... I’m planing on doing three oil and filter changes because the oil is bad. First one I’m going to run for a bit. Second I’m going to put a cleaner in there (any suggestions??) and final the third. Correct me if I’m wrong but the tranny and engine share the same oil right???
video link...
Old Sep 26, 2018 | 12:39 PM
F86's Avatar
F86
I would proceed very carefully here...
If this were my bike, I would remove the wheel, remove all the bolts and the pulley, inspect the holes in the wheel carefully, run a thread chaser through them (not an actual tap), and then replace the bolts and washers.
There are areas of the bike where it's possible I may be a little sketchy with things sometimes and still ride it, but any area that could lead to a wheel-related issue while riding is a different story...
On another note, welcome to the forum... FXDXT is a super cool bike!!!
Old Sep 26, 2018 | 01:15 PM
Feralyouth's Avatar
Feralyouth
6th Gear
video link... https://youtu.be/DBWHBBJdbKg
That sounds like a great idea... how would I know if the threads are bad? Also the video above does say it’s a common issue so I don’t think the threads are bad, unless the bolts rubbed and bent... but I will forsure check it out... thank you
