Fork oil
Old Nov 26, 2018 | 11:09 AM
Tileman2692's Avatar
Tileman2692
Default Fork oil
well did a search and didn't find what I was looking for, so! I ride a Dyna Super Glide. I slammed it with the front and rear Slammer kit and want to change the oil. I'm sure it needs it. Bought it with 19 k and have 26k on her know. What should I be using to change it with
Old Nov 26, 2018 | 12:01 PM
nevil's Avatar
nevil
I'm sure opinions will vary. However, if it was me I would start off with the stock oil. With less fork travel a heavier weight oil might make the ride a bit harsh but might prevent it from bottoming out. If you don't like the results then try the next heavier oil. You can always go back if that doesn't work out.
Old Nov 26, 2018 | 12:23 PM
Tileman2692
What's the fill hight. ( oil to top of tube )
Old Nov 26, 2018 | 12:53 PM
Sisu's Avatar
Sisu
This works for me.. My bike dove too much under braking so I added heavier springs soon after I bought it.. The levels were 4oz's different and the oil was Nasty..
Old Nov 26, 2018 | 03:28 PM
Monteman1971's Avatar
Monteman1971
The manual tells you how far to fill the tube...I think it was leaving 4 inches to the top. I lowered mine an inch and used the same rule.
Steve
Old Nov 26, 2018 | 08:29 PM
Tileman2692
Great! Thanks guys
Old Nov 27, 2018 | 07:53 AM
crusader1xxx's Avatar
crusader1xxx
Get a FSM if you don’t have one, get a fork oil measuring tool and do it right. It’s not rocket science but if you do it wrong it can effect the ride. Suspension is a safety issue so do it right.
moton pro makes a great tool for little money you can even get it through Amazon...sorry this is the Canadian site but it’s the same tool.
https://www.amazon.ca/Motion-Pro-08-0121-Fork-Level/dp/B000GZPCYI/ref=sr_1_4?ie=UTF8&qid=1543326629&sr=8-4&keywords=motion+pro+fork https://www.amazon.ca/Motion-Pro-08-0121-Fork-Level/dp/B000GZPCYI/ref=sr_1_4?ie=UTF8&qid=1543326629&sr=8-4&keywords=motion+pro+fork
i use Amsoil shock therapy 10wt with Traxxion springs and love it. I would add either race Tec or Rico emulator while your in there...
Old Nov 27, 2018 | 03:21 PM
Tileman2692
https://www.amazon.ca/Motion-Pro-08-...otion+pro+fork
ok.....looked rico up and nothing......
Old Nov 27, 2018 | 08:09 PM
John CC's Avatar
John CC
Ricor
I have their Intiminator emulators in my Legend TT and they are a huge improvement.
Old Nov 27, 2018 | 08:26 PM
NORTY FLATZ's Avatar
NORTY FLATZ
Just use any hydraulic oil with an ISO #46.
68 if you want thicker oil.
Something inbetween? You can mix the 2 oils if needed.
Shell makes Tellus
Texaco makes Rando
Choose one of those.
And yes, get an FSM!
(I use a combo of #46 & # 68 for my FXDL and Triumph Tiger.)
Tellus is what I use.
