High idle 2016 FXDB
Old May 26, 2019 | 10:35 PM
Skinny Rabbitt's Avatar
Skinny Rabbitt
6th Gear
Default High idle 2016 FXDB
I took my stock slip ons off just to see what it sounded like and i knew it would run rough and hot but after i put them back on it idles high and it sounds like there might be a exhaust leak from where the pipes bolt to the jugs. Did i damage the gaskets wiggling the slip ons off and/or throw the mapping off? Ill probably take it in to the dealer because its under warranty still but im curious as to what happened. This is my first harley but not my first motorcycle.
2016 Dyna Street Bob 1600 miles
Old May 26, 2019 | 11:11 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
I'm pretty sure the ECM had a heart attack and said "WTF" is this !
Old May 27, 2019 | 04:02 PM
Skinny Rabbitt
6th Gear
Any way to fix this?
Old May 27, 2019 | 09:05 PM
OldEnuf2NoBtr
Take it back to a Dealer and fess up to what you did. They might give you a free-bee or they might not. But be prepared to get a nice slap on the wrist!
Old May 27, 2019 | 09:09 PM
Skinny Rabbitt
6th Gear
If i take it to the dealer im playing stupid. Im trying to fix it so i don't have too
Old May 27, 2019 | 09:23 PM
Superdog3:16's Avatar
Superdog3:16
How long did you try riding it after ya mucked it up?
Did ya realize it idles to high/sounds like ****, and immediately shut it down?
If it's ridable, run it and see if it straightens itself out. Good luck.
Old May 28, 2019 | 12:38 AM
Skinny Rabbitt
6th Gear
I rode it for just a few hours over the course of one day. Didnt idle high untill after i put the pipes back on. Idle drops back to normal after it idles for about 10 -15 minutes. Thats why i suspect exhaust leak. Im thinking that once it warms up the pipes/gasket expands to plug the leak.
Old May 28, 2019 | 08:09 AM
Superdog3:16
Could be.
Old May 28, 2019 | 12:14 PM
nevil's Avatar
nevil
Instead of just "suspecting" it has an exhaust leak, why don't you check for it? Do it when cold, use smoke from a cigar, incense, etc.
Old May 28, 2019 | 01:06 PM
Skinny Rabbitt
6th Gear
I would but i dont have a garage. It stays under a car port and its windy in el paso this time of year.
Zoom1077
Milwaukee Eight (M8)
Aug 24, 2017 03:13 PM
P51Driver
Apr 13, 2013 05:26 PM
mattk22
Exhaust System Topics
Nov 18, 2010 10:35 AM
Dyna-Asa
Feb 28, 2009 12:42 PM
knubbel_7
Jul 8, 2006 08:54 PM
