95" upgrade
Old Oct 29, 2019 | 05:05 PM
dyna_rider84's Avatar
dyna_rider84
Default 95" upgrade
Hey everyone, time for winter upgrades. This year I have putting new cylinders on my 2000 fxdx (88ci). I have ordered the s&s 95" big bore kit. Now this past year I put new cams in, I am running the s&s .509's. My question is, will these cams be ok for the upgrade or am I going to have to get new cams again?
Old Oct 29, 2019 | 05:34 PM
brownie4412's Avatar
brownie4412
What’s your CR going to be? I think they’ll be fine. Might be better off using that money on headwork.
Old Oct 29, 2019 | 06:22 PM
66cruiser's Avatar
66cruiser
I picked 583G cams with the S&S 97" jugs. Great low & mid range torque, perfect for passing on 2 lane blacktop.
Old Oct 29, 2019 | 06:31 PM
F86's Avatar
F86
S&S 585 cams here, with their 97" pistons. And a bunch of head work.
Old Oct 29, 2019 | 07:07 PM
skills's Avatar
skills
Best to keep researching this one for now. I'd like to punch my 88 out to a 95 too but I was warned to stay with lower comp pistons or else change out my cams,I'm told my 551 S&S cams won't play nice with anything higher comp than 9.9-1 pistons. Apparently detonation becomes a threat due to the 551's intake valve timing which will raise the compression to this threshold. I must say, I really like the 551 torque & power band, I just want more cubes. My attitude is "Who cares if I can't say I have 10.5-1 or 11-1 pistons, what really matters is the actual combustion chamber compression that is determined by the combination of components you've married up in your build", I want all those goodies to play nice together! Any comments to this mindset?
Here's a link to a couple videos that are really good to help you get your mind around this topic.
Old Oct 29, 2019 | 07:27 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
When I had the 95" kit put in on my 02 Superglide they put in the S/E 203 cams that are equivalent to the S&S 551 cam. Real good power when solo and the power was still there with the increase in torque when two up.Roll on throttle passing worked real well. At the time the HD 96" came out and keeping up wasn't a problem till the new bikes went into 6th gear. Has a nice little lope to the idle.
Old Oct 29, 2019 | 07:51 PM
REW13's Avatar
REW13
Will be watching this thread.... I was just thinking of having a port done on my heads.... Not looking for massive hp... 80 to 85 if that...
Old Oct 29, 2019 | 09:07 PM
98hotrodfatboy's Avatar
98hotrodfatboy
If you go over to the Engine mechanical topics forum you'll see that most are going to a 98"er with 570 or 585 cams with compression to match the cam ivc plus head work. 110/105 is easily had..
Old Oct 30, 2019 | 03:46 PM
REW13's Avatar
REW13
I hate to say it, but to spend less is more... For me, guess I'm cheap, so a little head work should get me a little more hopefully?
That way it I do want a lot more I can just buy a new motor..
dyna_rider84
Apr 17, 2019 05:37 PM
mrsnipy
Mar 8, 2019 10:45 AM
viperpit07
Aug 25, 2014 10:38 PM
sickboy75
Oct 22, 2012 07:25 AM
Lundee
Exhaust System Topics
Jul 19, 2011 06:59 PM
