Throttle Cable too Long?
Sorry to waste everyone's time.
Okay, so I am starting to think I'm stupid. Turns out the cables were the correct ones. I worked with Dennis Kirk and they say the travel length on the cables is just about 5" on each cable. So, assuming that I ordered shorter cables if the travel length is still 5" it's still going to be too long, right?
Adjusting the cables isn't rocket surgery either so WTF? Am I doing something wrong? It's not the first set of cables I've done so I'm kind of at a loss.
The soldering is really quite simple. I used plumbing solder and paste flux, a torch, and a used (cleaned) 45 brass cartridge as a pot. You can get electric pots but I didn't want to spend the money for a tool I'd use just a few times in my life. Also didn't want to melt $50 worth of solder only to use $0.01 worth.
Poke the cable thru the end piece, fray and flare the wires so the end won't fall off, flux. The wires, dip the end in melted solder puddle for a second or two, remove, grind/file smooth. I do have a lot of experience brazing and soldering but
I had never done this before and used one piece for practice. Worked out fine and cost maybe $20 for a nice custom cable, including practice bits.
Only real trick is keeping the solder from creeping up the core wires above the end piece. That can make the cable brittle. Some folks just use a torch or high wattage iron to heat the end amd wire directly but it's harder to keep the wires cool above the end.
I reached out directly to LA Choppers, their customer service is top-notch. Spoke to a tech and it turns out that they actually make "adapters" that slip over the cables on the throttle body side and decrease the cable travel by a 1/4" on each. They're sending me a pair, priority mail for free and that should take care of my issue. Man, I'm excited to get my bike put back together!
