Replacing Clutch Cable Outer Without Removing Cover
Hi all,
I overfilled my transmission and the fluid is flowing into the clutch cable down by the transmission side cover. (I can see it because it's a braided cable/clear housing) I was not looking forward to replacing the entire cable again, but I had a thought as I closed up the garage: I think I can replace just the cable outern housing without having to remove the side cover.
I made the cable myself using a "build your own" kit that uses a removable barrel on the lever end, so here is what I'm thinking: I could disconnect the cable from the lever, lay it out "straight" from the side cover forward, remove the lever end barrel, thread the lower end of the housing out of the side cover, slide the outer off of the wire, fab up a new outer and reverse the removal process.
I think this will work and I won't have to deal with the side cover, clutch actuator circlips and all that...
Im confused. You overfilled your transmission with fluid and youre removing the cable again? Why not drain the fluid and refill the appropriate amount....?
The barrel end on an HD clutch cable takes a lot of stress; that sounds like a good way to walk home. As mentioned, if you aren't over filling the trans, the leak is probably the result of the o-ring at the trans end of the cable.
Now I'm confused as well. I checked my lubricant inventory last night and I have a partial quart remaining of trans lube. My owners manual says to use 28oz of lube for a transmission refill. I'm usually very specific about things like that so I likely did only pour 28oz of lube into the transmission. That means it is likely not overfilled (unless 28oz is too much). Does lubricant live in the side cover even when the transmission is properly filled? The o-ring sits on the outer base of the threaded fitting crimped to the lower end of the cable. It would prevent fluid from leaking onto the ground, but not into the interior of the housing. I suppose that would require a "seal" around the wire in the cable. What is happening here? Do I have an internal engine issue that is allowing an abnormal internal leak? Pressure in the side cover that shouldn't be there?
Hey bro yes the amountis for general fill on overhaul. fill with the correct level then you should be okay. sounds like your homemade cable is not sealed on the transmission end. why not use a quality cable.? no issue. and proper fill level.
