2000 Dyna intake leak mystery?
Old Jun 21, 2020 | 10:40 PM
fxr289's Avatar
fxr289
Default 2000 Dyna intake leak mystery?
I've got a 2000 dyna super glide that has continuously had an intake leak. It had a CV carb on it at one point and had a really bad intake leak. It would pop and spit pretty bad. So I had that carb taken off and had a brand new S&S super E installed. Now I've ridden the bike quite a bit since the carb was installed at least 400 miles. And once during the ride normally after it warms up it will kind of spit back in the carb. Now keep in mind it isn't doing this a lot normally one time a ride and I ride 50+ miles each time. So when I got back home I used the old gray bread trick of spraying carb cleaner around the intake to check for a leak. It shut off the bike. Now someone pointed out that the overspray could be getting sucked up by the air cleaner and that I should use an unlit butane torch. That's how I was taught to check. What do you guys think? Is this an intake leak or is there a better test. What is my next course of action?
Old Jun 22, 2020 | 11:13 AM
GREENOHAWK69's Avatar
GREENOHAWK69
Maybe I'm missing something, by why spray it in the intake? Wouldn't you be spraying around the manifold and exhaust ports - checking for leaks there?
Old Jun 22, 2020 | 12:09 PM
nevil's Avatar
nevil
If you go by the factory service manual they use the propane method. Of course they sell the tool to do that for too much money. You can use any propane torch (unlit) and see if you get the same results. With the propane it's easier to pinpoint where the tip is pointed, as opposed to a spray can which has a wide pattern. You still have to be careful not to spray into the intake.
Have you ever checked the intake gaskets or checked the manifold flanges to make sure they are flat with no distortions? A thick piece of glass is good for that.
Old Jun 22, 2020 | 11:13 PM
fxr289's Avatar
fxr289
I have never checked the flanges against a flat surface and I havent checked the seals since the new carb was installed. I will buy a butane torch and try to track down which side is taking in air. I'll try to keep you guys updated on the progress. Anyone have a fool proof method for seating those seals?
Old Jun 22, 2020 | 11:38 PM
JustDave13's Avatar
JustDave13
You're speculating. If you had an intake leak you would have caught with butane/propane at the intake to head gasket test. In my field we use propane and document any idle change.
BTW I have fuel injection and ocassionaly it will spit back through the intake... typical Harley.
Old Jun 22, 2020 | 11:41 PM
JustDave13's Avatar
JustDave13
When you spray, you spray. It forms a wide pattern that can be drawn into the air cleaner giving you false results.
Old Jun 22, 2020 | 11:58 PM
fxr289's Avatar
fxr289
Well I haven't ran the butane torch test yet so... I'll do it to be sure. Yeah harleys have their ticks. Id rather be overly cautious than be right and do nothing about it. Even if I speculate and I'm wrong it was worth being proactive.
Old Jun 23, 2020 | 12:00 AM
fxr289's Avatar
fxr289
I realized the fault of the spray test and that's why I asked around for a more specific method. I've never heard of anyone using a butane torch but once they explained it that made perfect sense. I was looking for a more precise method to diagnose something I suspected.
cuda67bnl
Exhaust System Topics
Apr 20, 2022 07:32 AM
JesseDyna
Carburetor Related
17
May 2, 2018 10:36 AM
95yj
EVO
Sep 5, 2011 09:52 PM
lennyb3us
May 24, 2010 11:57 AM
sheem2153
May 13, 2010 10:16 AM
