Ignition switch wiring 12' FXDB
Old Mar 11, 2021 | 09:38 PM
Steelyace's Avatar
Steelyace
3rd Gear
Default Ignition switch wiring 12' FXDB
I'm in the process of figuring out how and what all I need to order for an ignition relocation. In the process I noticed that there are only 2 wires going to the existing ignition switch, or am I missing something? If I'm not missing anything
can someone explain to me how this thing works? Only 2 wires doesn't add up for and off/acc/on style key switch.
Old Mar 12, 2021 | 10:39 PM
MRFREEZE57's Avatar
MRFREEZE57
if I remember, sometime back a guy on the forum explained that this is not an on/off switch but switches resistance. one resistor is for acc and the other for run. it works on a can bus. maybe someone else can chime in and say if is correct or not.
Old Mar 13, 2021 | 05:20 AM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
According to the wiring diagrams there are two wires:
Black/Green for ground to post G4 at the BCM
White/Blue as ignition switch input to post C3 at the BCM
The switch is a part of the canbus system like MRFREEZE57 explained
Old Mar 13, 2021 | 03:10 PM
Steelyace's Avatar
Steelyace
3rd Gear
This makes the most sense. It probably has 2 different rating resistors based on the 2 selections. Thanks you the info.
Nolot
EVO
Dec 29, 2020 09:55 PM
glidein wide
EVO
23
Mar 22, 2015 04:20 PM
jay3yzfr6
Aug 31, 2010 02:21 PM
781/2fxs
May 13, 2009 11:24 PM
skullguy
May 6, 2009 02:59 PM
