Last year i upgraded the cams in my TC 88 Dyna. I installed S&S 509 cams. I like it so far.
This year I decided to upgrade the cylinder bore to 95". Will i have to change the cams or the 509 would be compatible with a 95? I'm a bit concerned.
Yes you can.. But If your gonna do a big bore then go to 98", but to use higher lift cams you'll need head work which you should do then you can pick any cam and compression you want and the machine shop will do what is necessary to match everything based on your riding style and where you want your power.. Best to call one of the Indy's that support this site..
S&S know their own products pretty good. Following their recommendations my wifes stage 1 96 has 551 E-Z starts and my 103 has 583 E-Z starts. Neither has any headwork, both have extensive dyno tuning with the now obsolete SEPST and a top dyno operator. Both run smooth and strong. Ive had a few 100+ HP HDs; they were fun but didnt suite our riding style. An awful lot of money can be spent performance building HDs know what your looking for before you spend much more. Just my opinion
