Cable kits for drag bars?
Old Mar 4, 2023 | 11:56 PM
NeverDone's Avatar
NeverDone
Default Cable kits for drag bars?
It's easy to swap to different length ape hangers be it 12, 14, 16's because cable kits for these bars are available which include throttle cables, clutch cable, and brake line.
It's not so easy to convert to drag bars it seems.
I want to, I'd LOVE drag bars on my bike, but I'm stuck on the cables and brake line issue. Not so much the brake line, but definitely the cables.
A little more info:
The bars I want to use on my 2006 street bob are these linked below. I have them. They dont have clearance issues i have checked. I just have to put flush mount tank caps on and i'm good. I'm just completely stumped on the cables
https://www.jpcycles.com/product/692...drag-handlebar
I guess the simple answer is "Dont put drag bars on my bike!"
Here is a photo with them placed on the bike for the curious ones here:
Old Mar 5, 2023 | 04:39 AM
NeverDone's Avatar
NeverDone
It looks like an eight inch shorter clutch cable will work. Magnum makes one.
It feels like this build your own throttle cable with the 65 degree bend instead of a 90 degree will be the best bet
With the flush mount fuel caps installed, there should be no clearance issue.
It will have custom dynamics bar end running/turn signal lights and these joker machine knurled open end grips.
Old Mar 5, 2023 | 06:26 AM
TownesVanZandt's Avatar
TownesVanZandt
Cant help with the cables, but i believe magnum shielding makes all custom lengths? Anyway, good user name, I like the bar end indicators also.
Old Mar 6, 2023 | 04:36 AM
Rollcage's Avatar
Rollcage
Jump into one of the Fat Bob pages or FB groups, most of them will have guys that did bar swaps, and they come with 5 inch height bars so all their cables will work for you.
Magnum will have the single caliper brake line as the Fat Bob won't work for just that one.
Old Mar 6, 2023 | 05:28 AM
eighteight's Avatar
eighteight
Barnett / Magnum / Russell
Old Mar 6, 2023 | 09:38 AM
NeverDone's Avatar
NeverDone
Thanks! Also Venhill
I tried the magnum build your own throttle cable with the 45 degree bend it does now work well, so I ordered the cable with the 90 degree bend.
Tacked on more parts, adjusted angles of things, sat on the bike to get a better idea how it all works, feels, and how it will look. I like it!
Ordered more stuff so I can continue. I'll see if I can find something to do while I wait:
Old Mar 6, 2023 | 05:24 PM
RevHendo's Avatar
RevHendo
6th Gear
I like it. Although I personally hate waiting for parts.
Are those Progressive shocks on the back?
Old Mar 6, 2023 | 06:58 PM
NeverDone's Avatar
NeverDone
It has progressive 412 11" shocks on the rear, and the front has a progressive fork lowering kit installed where I just cut it down to taste- I estimate about 1 inch lower give or take.
It really does royally suck waiting on parts!
Old Mar 7, 2023 | 06:55 AM
NEWROADSTER's Avatar
NEWROADSTER
I have a similar build on my bike. Mine runs the Wide Glide set up for the bars, so mine have a riser from the triple tree to the bars. I had a custom front break cable made but the rest are wide glide cables on my Street Bob. I think I have a receipt with the part numbers if that would help you but without the risers my cables may still be to long.
s13steve
Feb 11, 2019 04:44 PM
Murphy832
Jun 23, 2017 07:55 AM
Interceptor9C1
Jul 27, 2012 02:50 PM
sharksparts
May 25, 2012 11:01 PM
BLKnCHRME09Deluxe
Jun 27, 2009 12:19 PM
