Twin cam sputtering
Old Apr 23, 2025 | 05:29 PM
joeydyna's Avatar
joeydyna
Default Twin cam sputtering
2006 street bob with the 88” twin cam, around 3000-3300 rpm’s I get a sputtering or almost like a clogged fuel filter? It’s only if I hold it at those rpm’s trying to just cruise. 1st through 4th it seems like it happens in those gears. It accelerates up no problem, only happens when staying at those rpm’s. Replaced the tps already, no luck
Old Apr 23, 2025 | 06:09 PM
Jackie Paper's Avatar
Jackie Paper
Needs more fuel at 3500. What's it do there? Plugs good? Maintenance up to date? First sign of a fuel filter on a STOCK FI is idle. A modified engine may be different if the tuner adds fuel to idle mix.
And codes?
Old Apr 23, 2025 | 07:18 PM
joeydyna's Avatar
joeydyna
And codes?
at 3500 it runs fine. Plugs were done a couple years ago. Could be worth changing. All fluids have been changed. Forgot to mention bike has an Andrew’s cam with a dynojet power vision tune. Just scanned it and I’m getting a p0118 code
Old Apr 24, 2025 | 08:20 AM
Bubba Zanetti's Avatar
Bubba Zanetti
How is the bike at idle and low RPMs?
Old Apr 24, 2025 | 08:30 AM
702's Avatar
702
That looks like a coolant temp code. Wanna try again?
Old Apr 24, 2025 | 08:44 AM
joeydyna's Avatar
joeydyna
idles fine, rpns up until 3000 are good
Old Apr 24, 2025 | 08:46 AM
joeydyna's Avatar
joeydyna
Old Apr 24, 2025 | 08:52 AM
702's Avatar
702
Odd. Quite odd.
Those are historic codes. Clear them, change your plugs, see what happens.
Old Apr 24, 2025 | 08:53 AM
Super Glidester's Avatar
Super Glidester
Is it sputtering or chuggung? possible primary chain ajustment? what i had with mine but mine is carbed.
Old Apr 24, 2025 | 08:54 AM
joeydyna's Avatar
joeydyna
it’s definitely more of an engine sputtering than a chugging from a chain
