FActory security system question
Old Oct 15, 2007 | 07:17 PM
eddieape81's Avatar
eddieape81
Default FActory security system question
Ok all, Kinda confused reading my owners manual when it come to the factory security system on my 06 superglide. If I pull the battery out of the bike for the winter, when i re-install it in the spring am I going to have a problem getting the bike to start due to the alarm system? I dont arm it and to be honest I was thinking of just removing the system from the bike alltogether. Has anybody gone this route before? Any advice would be great.
Old Oct 15, 2007 | 07:44 PM
JohnT's Avatar
JohnT
Default RE: FActory security system question
When you disconnect the battery, the only effect will be that you will lose whatever password code you entered into it, if any. When you reconnect the battery, it will default to the original password code that is indicated in your user manual and it will not be armed. It will not cause a problem with starting the bike.
Old Oct 15, 2007 | 07:45 PM
eddieape81's Avatar
eddieape81
Good deal. Thanks.
Old Oct 15, 2007 | 08:26 PM
Splatter's Avatar
Splatter
Just a warning -- don't simply pull the TSSM out of your bike. The ECM knows it's there and won't start if the module has been removed or replaced. That information is stored in flash memory and removing the battery won't change it. Your Harley dealer has a program that will tell the ECM it's gone if you decide to get rid of it. Have them de-program the ECM before you pull the module.
Old Oct 15, 2007 | 08:29 PM
eddieape81's Avatar
eddieape81
Didnt know that.
Thanks for the info splatter
Old Oct 15, 2007 | 09:15 PM
bikerdog134's Avatar
bikerdog134
get a battery tender and leave it in
Old Oct 16, 2007 | 11:08 AM
cigarman's Avatar
cigarman
ORIGINAL: bikerdog134
Good advice. I have a battery tender on my Corvette and the battery has held up well. originally I took it out and that battery had the shortest life of any I've had.
I put one on my 1200C and it also was fine.
Make sure you use a "battery tender" brand or one of the others with a float charge system, not one that hust trickle charges.
WNMORE
2014-2024 Touring Models
Dec 17, 2017 11:12 PM
herbacide
Feb 18, 2017 11:21 AM
shovelheadroad
Sep 9, 2013 10:00 PM
Twinrider
Nov 3, 2012 08:46 PM
Hoffy49
Jan 12, 2010 06:55 PM
