Replacement bars on Dyna
On my Sportster I noted that the distance between the headlight eyebrow mounting bolts is the same as the distance between the mounting holes on the speedo or speedo/tach bracket, and the holes/bolts are the same size (5/16"). I found this out because I was thinking about mounting the speedo/tach bracket to the eyebrow holes with long bolts and spacers (forget it, it doesn't work and looks even stupider, because your speedo is on top of your headlight). So this bracket can be used to angle the instruments back down after installing pullback risers, if you mount it to the bar clamp (use longer bolts and maybe spacers beneath it), and then mount the instruments to it. It angles them back much closer to stock, and moves them a little bit further forward, maybe an inch, both of which are Good Things. If it works on a Sportster, it should work the same on a Dyna, right? Will try to post photos soon, it's easier to understand if you see it. The bracket is 2d column, 2d item down at
http://www.jpcycles.com/catalog/2006...alog/0303.html.
...and no biggie that it "only works for narrow glide forks", because you're not going to use it on the forks anyhow. The speedo mount spacing hasn't changed for '06; I think it's been the same for years and years. Now I need to know if anyone has put modest (say 4") pullback risers on an '06 Dyna SuperGlide or Custom and if they had to extend any wires or cables? I like the angle and rise of the stock bars, but they're too far away for my little T-Rex arms.
Gary
