internal wiring
Old Jan 7, 2008 | 06:52 PM
amish's Avatar
amish
Default RE: internal wiring
Loner Industries
Its not that had just take your time. There is a good thread on taking the plug under your tank apart and then running the wires. This will save you a lot of time over cutting and splicing. Personally I used weed eater line to fish through the bar. Then I attached the wire to it and carefully pulled the wire though. Also note on the gimps there is a small hole at the bottom bend. I worked each wire from the control through the small hole and then to the hole in the center of the bar. I would suggest doing this two step process one wire at a time.
where is this thread? do u have a link
thanks
Old Jan 8, 2008 | 10:34 AM
fiend138's Avatar
fiend138
Here is is, it is a good one to book mark.
https://www.hdforums.com/m_1328001/tm.htm
Old Jan 8, 2008 | 08:41 PM
JayFromPa's Avatar
JayFromPa
Those bars are wicked sick Loner. Almost wish I had seen them before I did my apes, but my speedo would have looked pretty stupid up there.
Old Jan 9, 2008 | 10:50 AM
fiend138's Avatar
fiend138
Thanks, that bike was fun to ride, tall narrow bars. I bassically took the sock night trian drag bar with and pull back and made a set of Z bars + 2.5 height. Then I made those risers 10", I got a little twist out of them but only if you tryed to. one of the best things was the two punisher shulls on the riser caps staring back at me, you can kind of see it in this pic.
brian.macartney88@gmail.com
Feb 26, 2016 04:49 PM
jims79flh
Jan 1, 2011 10:51 PM
jstreet0204
Jan 30, 2009 08:18 PM
The Baron
Feb 6, 2008 10:01 AM
imboden
Jun 8, 2007 03:47 PM
