Stripped primary inspection bolts
Old Feb 14, 2008 | 12:31 PM
kk6pg's Avatar
kk6pg
Default RE: Stripped primary inspection bolts
ORIGINAL: gman
When you get the old ones out, go to ACE hardware and get some chrome allen head bolts and washers. Makes it a whole lot easier next time you remove the cover. Some folks say to go with stainless, but IMHO,if you break one of them off you are really in touble. pretty much impossible to drill into one. I just went with the chrome allen heads and I never have a problem on either of my scoots when removing or installing them.
I'm inclined to agree with you, but for different reasons. I've had way too many occasions with thread galling when it comes to stainless and aluminum alloy combinations without using anti seize.
And this isnt a place where I'd want to use anti seize
Old Feb 14, 2008 | 08:14 PM
tattoofreaksb's Avatar
tattoofreaksb
ORIGINAL: HOGRIDA_06
Drill the heads off with a 1/4" bit. Once the cover is off you'll be able to remove the bolt with vise grips. When it's time to put the cover back on use stainless steel socket head cap screws.
Some real good advice right here. Replaced all my bolts with the Diamond Engineering S.S. groove series bolts.
Kevin714
Mar 15, 2017 09:10 AM
DayzedAndKunfoozed
Jun 28, 2015 06:35 PM
bmwr69s
Jul 15, 2010 03:30 PM
meatball
May 25, 2007 12:38 AM
DGlide04
Aug 22, 2005 11:01 AM
