2008 fatbob problems (updated)
Old Feb 13, 2008 | 10:40 PM
BOBFATBOBTHATIS's Avatar
BOBFATBOBTHATIS
6th Gear
Default 2008 fatbob problems (updated)
Hi:
My fatbob has 1400 miles on it now and the neutral light started coming on as a flicker in all gears and now it's shining brightall the time in all gears. Took it to the service department and had the neutralswitch cleaned. Well that helped for about 100 miles and itcame back on full time all gears. Now the 6th gear indicator lampwas working part time for a while now it's not working at all. Anyway it's going back to the dealer next week to see what is going on. Anyone have any of these glitches? Thanks.
Jeff.
Update:
I found the problem myself the wire harness to the neutral light switch and the vehicle speed sensor (has something to do with the 6 gear???) was rubbing causing a short on top a Allen head bolt underneath the starter. I moved the harness off the bolt and put a black plastic plug over the bolt head for insurance no more problems.
Old Feb 13, 2008 | 10:57 PM
etbiker's Avatar
etbiker
Default RE: 2008 fatbob problems
My 2006 Superglide started the flickering neutral light a few weeks ago. Spent 2 days at the dealership, they changed the switch, that didn't fix it. They kept it and worked on it, they thought it was fixed but they didn't know what they did to fix it...it isn't fixed.
I hope someone has a solution!
Old Feb 14, 2008 | 06:37 PM
TARTAN2's Avatar
TARTAN2
Side stand switch registered a fault for a day but has gone now but will get it checked when next at the dealer . No problems with the neutral ...fingers crossed
Old Feb 14, 2008 | 08:02 PM
YesterdaysCorn's Avatar
YesterdaysCorn
That's a bummer.....little things like that drive me crazy. So far so good on this end, hope ya geter fixed soon.
Old Feb 14, 2008 | 09:36 PM
DougsDyna's Avatar
DougsDyna
ORIGINAL: etbiker
There was a safety recall on the 06 Dynas for the nuetral switch assembly (not the switch itself). You should have got a recall notice on this. The first 13,400 or so were definitely involved.
A few other things can cause the nuetral light to start acting up. Recalls are good for the life of the bike, they not a warranty issue.
Good luck,
DougJ
Old Feb 14, 2008 | 10:13 PM
BOBFATBOBTHATIS
6th Gear
ORIGINAL: etbiker
copy and paste in search.
SAFETY RECALL 0124–2006 DYNA TRANSMISSION
daleg3556
Apr 4, 2010 01:39 PM
chagwood
Jul 3, 2008 07:55 AM
CKinAZ
May 27, 2008 01:29 PM
Trojan_Hog
Jun 30, 2007 09:06 AM
ext1bab
May 29, 2007 09:07 PM
