Turn Sig relocation 49mm
Old Mar 1, 2008 | 10:14 PM
Dynaflyer's Avatar
Dynaflyer
Default Turn Sig relocation 49mm
Hey All,
Has anyone used these on their WideGlide Forks? http://www.kuryakyn.com/products.asp...ey&ci=2591
Or These? http://www.kuryakyn.com/products.asp...ey&ci=3023
Seems to me I remember some posts a few months ago on this.I have a2006 Fxdl with 49mm Forks and Wideglide tripples.
I would do a search but as you know it is down.
Doing a WideGlide conversion on the LowRider and the Pinch bolts on theWideGlide trees are on a 45* angle which eliminates my previous Turn signal mounts.
Any Ideas? What are you all running for Turn signals on your Wideglide Fork Tubes ???
Thanks
Old Mar 1, 2008 | 10:29 PM
Muddyape's Avatar
Muddyape
Default RE: Turn Sig relocation 49mm
Im using WG trees with my standard Street Bob 49mm tubes and mounting the signals with the 49mm Kuryakyn clamps just above the lower tree. I'm sorry but not sure what the question was....if it is can it be done? then yes. Metal_Mike is running the same setup on his and he's got some pics in his gallery. BTW search function is working again, at least it was yesterday.
Old Mar 1, 2008 | 10:42 PM
Dynaflyer's Avatar
Dynaflyer
Thanks Muddyape,
The Kury Clamps should work fine, Was curious what others have done and Maybe other options.
I have the HD Bullet housings, Do you have to change the bolt on the Kury Clampsto work with the HD Signals? For some reason I thought the Kurys were made for Kury Silver bullets
Old Mar 1, 2008 | 11:12 PM
JayFromPa's Avatar
JayFromPa
The bolt that comes with the clamps won't work with HD sigs. You'll need a 5/16 bolt.
Old Mar 1, 2008 | 11:43 PM
Dynaflyer's Avatar
Dynaflyer
Thanks Jay!
The search is up and running, found a bit of info about the 5 /16 bolts needed.
Man walking through turnstyle at airport with zipper open, Going to Bangkok ! [:@]
Old Mar 2, 2008 | 06:46 AM
jsbridgew's Avatar
jsbridgew
the bolt that comes with the kury clamps is a 5/16 -18 (coarse pitch) ...you need to replace them with 5/16 -24 (fine pitch) ....length, spacers, and jam nuts is up to you, really
Old Mar 2, 2008 | 07:39 AM
Bottomend's Avatar
Bottomend
This is what I did...
Old Mar 2, 2008 | 09:06 AM
Dynaflyer's Avatar
Dynaflyer
Now That Looks Cool ! Like the Bag placement as well. Nice Ride ya have there.
Went and looked at your Photo Gallery, Daayumm ! I like those tins man!!!
Saw a set similar to yours at the dealer. If I ever change them, Thats what I would like to get. Bad A$$ look!!!
Old Mar 2, 2008 | 09:21 AM
Dynamite17's Avatar
Dynamite17
ORIGINAL: Dynaflyer
Hey All,
Thanks
I put on the JP Cycles kit (very similar) and posted smoe detailed installation pics HERE
B
Old Mar 2, 2008 | 10:00 AM
Arcane's Avatar
Arcane
ORIGINAL: Dynaflyer
Hey All,
Thanks
I went through the turn signal mount routine with Kuryakyn not long ago. The #2390 mounts are not available for the 49mm forks. I know that they say that they are but if you look at the order page you will see that you can only order the 31mm and the 41mm mounts. Thinking that it was a typo and that perhaps the 49mm were actually available I called and the answer that I received was that the order page is correct, only the 31mmmand 41mm are available. See the link (order page) below, look at the order now area.
http://www.kuryakyn.com/products.asp?bn=harley&ci=2591
I ended up using the Kuryakyn ring type mounts #2278 , but I recently purchased a set of the mounts from J&P, I will give them a try and see which set I prefer.
Arcane
joker2041
Apr 12, 2020 03:06 PM
jram67
Feb 20, 2012 09:08 PM
WVNightrain Rider
Jun 24, 2010 08:17 PM
Narco101
Aug 3, 2009 07:58 PM
stagolee
Dec 13, 2007 04:08 PM
