ignition switch
Old Mar 3, 2008 | 04:47 PM
lee's Avatar
lee
Default ignition switch
ive orderd a console mounted switch can anyone that has done this mod post a basic sketch which wire goes where,wish me luck many thanks in advance
Old Mar 3, 2008 | 06:22 PM
1nuckenfut's Avatar
1nuckenfut
Default RE: ignition switch
Lee, I am planning the same mod soon. Check out a members profile named walter windbag. In his posts there is a step by step description of the project. Also, you can do a search for "ignition switch". There are several posts there that talk about this mod. There are several members that havedone this project.Good luck.
Old Mar 3, 2008 | 06:29 PM
pappy43's Avatar
pappy43
You don't give a clue about what you ride, but anyway,this mod has been all over this forum for several months....do a search for "ignition swith relocate" and you will be able to gather all sorts of info from those that have "been there/done that" . Good luck with it.
Old Mar 3, 2008 | 06:43 PM
lee's Avatar
lee
its only the switch wiring i need to see ,no diagrams or pics of actual wires to switch on any searches.cutting/fitting/location no probs.cheers
Old Mar 3, 2008 | 06:53 PM
kk6pg's Avatar
kk6pg
This thread ought to steer you in the right direction
https://www.hdforums.com/m_1449279/tm.htm
The red wire goes in the middle. Cant remember which side the red with blk stripe goes, but it wont take but just a second to figure out. I'm wanting to think it goes on the left when youre looking at the bottom of the switch, but I could be wrong (what else is new)
Old Mar 3, 2008 | 06:59 PM
rok312's Avatar
rok312
If you got the later-model switch with the three connector points: See this post
Old Mar 3, 2008 | 07:10 PM
lee's Avatar
lee
cheers rok thats what i need,just waiting on the switch,also fitting braid to all wiring & some 12in narrow apes,to get that fat front end look. thanks
Old Mar 3, 2008 | 08:27 PM
HD4DP's Avatar
HD4DP
As you look down at the switch:
Left Red/Black
Middle Solid Red
Right Red/Grey
glidein wide
EVO
23
Mar 22, 2015 04:20 PM
streetleon
Jun 21, 2012 02:45 PM
781/2fxs
May 13, 2009 11:24 PM
peippert
Aug 20, 2008 09:34 PM
markuhen
Jul 4, 2006 06:11 PM
