What the &%$#?
Old Aug 7, 2008 | 06:11 PM
lonerider53's Avatar
lonerider53
Don't know the answer, mine only died like that once, but that was a few milliseconds after I got T-boned at about 35 mph................. guess that don't count
Old Aug 7, 2008 | 06:40 PM
harper764's Avatar
harper764
i had a problem like that. it was intermittent dying like that. listen for your fuel pump to come on when you turn the run switch to run with the ign on. if it makes the sound its always made, try jiggling your fuel pump relay then try again. my problem was a terminal going into the relay panel wasnt seated and it was causing the fuel pump to lose power. take a look at the terminals and if one is further back in the panel than the others, thats a problem. may not be the one, but sounds like the exact same thing i had to fix. and it was a Btch gettin that terminal seated.
Old Aug 7, 2008 | 06:45 PM
harper764's Avatar
harper764
Originally Posted by lost6009
Anyone get a conclusion to this. My '06 bob did it to me this morining on my way to work too. This was the second time and I know I didn't hit the kill switch this time (that's what I figured happened the first). Bike just dies, I still have all power and speedo goes to 0.
exact same symptoms i had. check the fuel pump relay terminals. that was killing by bike the exact same way
Old Aug 7, 2008 | 06:48 PM
harper764's Avatar
harper764
btw, the fuel pump relay is on the bottom. 2nd one from the left on my 07
Old Aug 7, 2008 | 09:43 PM
FXDF MYK's Avatar
FXDF MYK
It was my battery connections that caused mine
hdelectra
Jun 16, 2019 10:26 PM
hd4evr2008
May 15, 2017 07:29 PM
MoosesUltra09
Apr 29, 2015 08:37 PM
akahny
Jul 25, 2012 04:06 AM
glebo
Jul 3, 2007 12:14 PM
