Anyone change there front end on a superglide?
Old Apr 12, 2008 | 06:24 AM
intruder400ex's Avatar
intruder400ex
Default Anyone change there front end on a superglide?
I was just thinking of putting a beefier front end on my sg and was wondering if anyone has done a swap and what it took to do it. If you dont mind a quick detailed description
Thanks
Steve
Old Apr 12, 2008 | 06:46 AM
jmpancoast's Avatar
jmpancoast
Default RE: Anyone change there front end on a superglide?
ORIGINAL: intruder400ex
Thanks
Steve
There are several guys who have done Wide Glide front ends on the Dynas. Dynaflyer, Muddyape, Jackyl, and mudpuddle are a few who have done this in various configurations.
I just recently installed Low Rider trees and new sliders on an 06 FXDI. The actual process of swapping the front end was not difficult at all. The info posted by the guys listed above, and I'm sure many others, could be a huge help in finding and deciding which components you can go with.
EDIT: Just noticed you have an 04. Check out Naz_Man. He has a sweet 05 SG with a WG front end.
If you're looking for something other than the WG type front end, sorry for being off base.
Old Apr 12, 2008 | 02:11 PM
intruder400ex
Its all good but im actually looking for something more beefier similar to dyna bob front end or fat boy but thanks for the info anyway.
steve
Old Apr 12, 2008 | 03:26 PM
glide05's Avatar
glide05
not a tough job - but if you change to wide - you will need to consider a number of things:
1. wheel spacers
2. headlamp mount
3. fender mount/spacer
4. disk spacer (unless you change to a wide hub wheel)
most aftermarket setups have a 3/4" axle, you have a 1" axle.
these items add up $ quickly. also - get a good torx bit for the stock pinch bolts - you really need to lean on them to get them loose - you will trash a cheap bit.
Old Apr 12, 2008 | 03:33 PM
wafu321's Avatar
wafu321
How about something like these.
http://www.storzperf.com/jpgs/page10.html
Old Apr 12, 2008 | 07:54 PM
FastHarley's Avatar
FastHarley
Former Sponsor
K? This is the first photos with work in progress at that time.
[IMG]local://upfiles/29413/C17534D50FF941BB87F402DA071A2CE9.jpg[/IMG]
Willy723
Oct 5, 2012 05:20 PM
bzzrd2
Dec 14, 2011 07:16 PM
reedster70
May 12, 2011 01:58 AM
HDJaco
Mar 18, 2009 09:08 AM
tenvar
Mar 1, 2007 08:10 PM
