Gasket
Old Jul 2, 2008 | 09:18 PM
Double00Aught's Avatar
Double00Aught
Default Gasket
Stopped at a friends house tonight for a couple beers, while sitting there I noticed the gasket between the motor and the tranny was very moist. Moist enough that it caught my eye, and I could wipe it dry again with a rag. This friend of mine says it's normal, but I want more opinions. Motor only has 1700 miles on it. So is it normal for this gasket to be noticeably wet with oil, or do I need to ask the stealer about warranty issues?
Old Jul 2, 2008 | 09:55 PM
mud's Avatar
mud
Default RE: Gasket
ORIGINAL: MTBlood
There is no seal between the motor and transmission
that you can see, unless you separate the two units.
mud
Old Jul 3, 2008 | 04:33 AM
Double00Aught
Default RE: Gasket
I see, well the seam between the two units is where I noticed it being wet with oil. I wiped it dry and am going to watch and see if it does it again.
Old Jul 3, 2008 | 05:01 AM
maddghost's Avatar
maddghost
Default RE: Gasket
mine was getting moist too ,but it was between the crankcase and front of primary cover. There is a thick white gasket there. the stealer says it was the moco's fault and that&nbsp\\;there was a kink in the gasket,almost&nbsp\\;600 miles later now and all is well. When i posted it another member suggested, that in 2008 we should be able to keep the liquids where they belong! If it comes back,and i suspect it will have them fix it pronto!
Old Jul 3, 2008 | 05:27 AM
LownBlue's Avatar
LownBlue
Default RE: Gasket
It is not normal. Mine has never leaked oil anywhere except for minimal blow-by in the
air cleaner which is normal. I would get it checked out.
Old Jul 3, 2008 | 05:32 AM
Bossman1's Avatar
Bossman1
Default RE: Gasket
Enginrs and gearboxes etc are not designed to leak.
Show dealer ASAP!!!
Old Jul 3, 2008 | 03:30 PM
Double00Aught
Default RE: Gasket
I'm going to keep an eye on it and make sure it's not a fluke. I had a pretty serious amount of blow-by as well. I cleaned that up, so now I'm going to make sure the two aren't linked in some way. You can bet your sweet *** they're gonna make it right if there ends up being a problem.
Old Jul 7, 2008 | 07:54 AM
Double00Aught
Default RE: Gasket
Looks like maybe the blow-by was being collected on this seam. Rode for 100 miles this weekend and it was dry as a bone.
LQQK_OUT
EVO
22
Jul 10, 2016 11:25 AM
ffsaulshd
May 11, 2009 06:45 PM
Bulldog21
Aug 21, 2008 10:15 PM
mulch63
Aug 7, 2008 06:24 AM
BiggestDawg
Feb 25, 2008 04:41 PM
