Idle high after run
Old Jul 3, 2008 | 12:23 PM
larazauk's Avatar
larazauk
Default Idle high after run
Has anybody else experienced this?
After I've been riding at a constant throttle opening (no matter what speed) when I close the throttle the revs stay at about 2500-3000. If I turn the bike off and restart it idles normally.
I have changed the throttle cables recently and I think I may have done something wrong? apart from this the bike runs perfectly.
Any ideas??
Old Jul 3, 2008 | 12:34 PM
bdasource's Avatar
bdasource
Default RE: Idle high after run
i have the same problem, haven't been able to find a cure yet.
Old Jul 3, 2008 | 12:43 PM
Marksman's Avatar
Marksman
As I recall (don't have my manual here) there are two cable right? One actually opens the throttle and on closes it. Like a continuous loop.
&nbsp\\;
I would check the cables at the carb. Open and close the throttle (bike off) and see what the heck is going on. Sounds like an issue with the closing cable.
&nbsp\\;
Good luck.
&nbsp\\;
sargek's Avatar
sargek
My carb'd WG does the same thing after a long run. When it gets hot, it idles high. No idea what rpm's since I have no tach, but I've set the idle at 950-1000 with my maintenance tach and the hot idle seems to be quite a bit higher than that. 2500-3000 seems really high.
larazauk - is your bike injected? If so, guess in your case the computer controls the idle but I don't know much about FI. Nice pipes - crossbacks? Heard a sound clip of those and they sound great.
Old Jul 3, 2008 | 01:20 PM
larazauk's Avatar
larazauk
ORIGINAL: Marksman
Good luck.
Cables seem to be doing what they're supposed to [&:] in the manual one is labelled as an 'idle cable' and wondering if I've adjusted it wrong but then it would be happening all the time?
Old Jul 3, 2008 | 01:22 PM
larazauk's Avatar
larazauk
ORIGINAL: sargek
Yep mines injected.
Really pleased with the pipes, great sound and seem to be good quality
Old Jul 3, 2008 | 01:28 PM
Frankster69's Avatar
Frankster69
Mines an 02 and its been doing that from the time I got it.
Old Jul 3, 2008 | 01:33 PM
dyna07custom's Avatar
dyna07custom
is there anything left to roll back in throttle if not its not the cables Check throttle body and make sure there is noting there dirt etc other than that no clue. Mine will idle a little faster when i come down from speed but not 2,500-3,000 maybe 1100 and after a few seconds returns to normal
Old Jul 3, 2008 | 04:01 PM
gtfm's Avatar
gtfm
Did you move the throttle stop?
Old Jul 4, 2008 | 01:00 AM
larazauk's Avatar
larazauk
ORIGINAL: gtfm
Not that I'm aware of, if I had wouldn't it idle high all the time?
tar_snake
EVO
Aug 26, 2017 07:29 AM
larazauk
Exhaust System Topics
Jul 4, 2008 11:25 AM
UltraKla$$ic
Jul 2, 2008 03:23 PM
Drtbag
Jun 26, 2008 06:09 PM
WaterBuffalo
Apr 15, 2008 09:47 PM
