Found Fluid on Floor
Old Mar 20, 2005 | 01:08 AM
srob's Avatar
srob
Default Found Fluid on Floor
After being gone all week, I went and uncovered the bike for a ride. The first thing I saw was about a half dollor size spot of fluid under the back of the tranny. I about flipped out. After checking things out, I found the tranny drain plug almost out. Must have just vibrated loose. Does anybody use blue lock tight on these or is it ok to use it. I have never had the plug back out before. The last time it was touched was at the dealership. I hope this will not be a recurring problem.
Old Mar 20, 2005 | 01:26 AM
pococj's Avatar
pococj
Default RE: Found Fluid on Floor
LocTite the booger, and be careful not to strip the threads in the case.
Old Mar 20, 2005 | 02:22 AM
Johnny's Avatar
Johnny
I know my mechanical skills are rusty and fading, but isn't the white thread loc for threading thru a fluid passage?
Old Mar 20, 2005 | 03:05 AM
Markcuda's Avatar
Markcuda
I do all of my fluid changes and my plugs have never backed out.
Just tighten them down good and you won't need any "Loc-Tite"
Old Mar 20, 2005 | 11:15 AM
billnourse's Avatar
billnourse
I agree with Mark, I have never had a plug come loose. Maybe the tech at the dealer didn't get it tight.
Regards,
Bill
Old Mar 20, 2005 | 11:58 AM
Scout's Avatar
Scout
I gree with Johnny, I use loctite white 565, High performance, won't break down till 465 degrees and stops fluid. Red, bue and the like hold bolts, but not great with fluid.
Old Mar 20, 2005 | 12:40 PM
srob's Avatar
srob
Thanks for the info folks. I'm gonna keep an eye on this for now. I tightened it, but I'll keep looking.
Thanks again.
Old Mar 20, 2005 | 11:44 PM
John TN's Avatar
John TN
Another dealer mechanic screw up. You're lucky the plug did'nt fall all the way out and do some major damage or cause you to crash.
I like to use liquid teflon on all my drain plugs, properly torqued of course.
nighttrain72970
Apr 4, 2019 09:26 PM
SouthpawHD
Oct 29, 2012 05:50 PM
dibe
May 14, 2010 08:21 PM
met.75
Apr 29, 2009 05:09 AM
cznmike
Jun 3, 2008 06:53 AM
