2006 Dyna FXDL...electrical problem
Old Oct 28, 2008 | 09:42 AM
mdrogers1's Avatar
mdrogers1
1st Gear
Default 2006 Dyna FXDL...electrical problem
I have question and need some help. When the key is not in the ignition my speedometer/tachometer gauge lights remain illuminated.
It is killing my battery....
Can anyone help?
Old Oct 28, 2008 | 10:43 AM
Dodzi's Avatar
Dodzi
See your other thread - sounds like your turning the key to ACC before taking the key out?
Old Oct 28, 2008 | 11:59 AM
JRK5892's Avatar
JRK5892
agreed
Old Feb 20, 2010 | 03:32 PM
desertrat_18's Avatar
desertrat_18
2nd Gear
Interesting. It seems I may be having a related problem... I ride a 2006 FXDBI and am also having trouble with my speedo lights. In fact, I am also having trouble with my horn and turn signals. When I turn the key to either the start or ACC position, everything powers up just fine, except my speedo lights/odometer. Heck, my speedo doesn't even work now! Also, when I hit my turn signal switches, the signals don't work, either. Same for the horn. I checked the fuse and it was blown. Replaced it and POP! I traced the circuits out in the manual and the speedo lights, turn signals, and horn all run through the same fuse to the ACC position on the ignition switch module. I looked inside the rats nest of wiring in the neck/frame and even took a look at the speedo and ignition switch and couldn't SEE anything wrong. I suspect it might be the ignition switch module at fault, which sucks since it is not a repairable part. Also lending to my suspicion of the ignition switch is the fact that the other day I couldn't get the fork lock to engage; I noticed the locking pin wasn't ligned up with the hole inthe bottom tree, so I pushed it back in place with a small bolt I had. Everything worked fine for a bit, but now I have no turn signals, horn, odometer, speedo light, or speedometer. Not sure if this is related to your problem, but I hope it helps. Any ideas on my problem?
Old Apr 15, 2017 | 01:08 PM
David Gow's Avatar
David Gow
3rd Gear
Default Fuses
Changed 15 amp fuse, it blew as soon as I turned the key on.. Bummer!
Could it be a relay? I pulled ALL the FUSES & RELAYS and cleaned them. Any more ideas?
Old Apr 15, 2017 | 01:10 PM
David Gow's Avatar
David Gow
3rd Gear
I cleaned all and replaced one blown fuse, but blew as soon as I turned the key on!
Old Apr 15, 2017 | 01:18 PM
beanoboy's Avatar
beanoboy
You have to check all the related wiring, you have an electrical short somewhere. Carefully examine all the connections and exposed wires...b.
Old Apr 15, 2017 | 08:13 PM
multihdrdr's Avatar
multihdrdr
Originally Posted by David Gow
... but blew as soon as I turned the key on!
You should see what happens when you push down on this handle
Old Apr 15, 2017 | 08:21 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Model and year of bike?
Did this problem pop up out of the blue, or did it start after you performed work on the bike?
Which fuse?
Old Apr 16, 2017 | 03:00 PM
David Gow's Avatar
David Gow
3rd Gear
Got er fixed, replaced speedo sensor. 06 Dyna Superglide...
desertrat_18
Jul 31, 2019 10:09 AM
luckytim
Jan 13, 2014 06:18 AM
alexl
Jul 11, 2013 12:33 PM
Greco_Superglide
Apr 30, 2011 12:51 PM
gsgtrman
Aug 10, 2010 06:20 AM
