oops
Old Dec 3, 2008 | 05:16 PM
jjwin98's Avatar
jjwin98
Default oops
Well I started my winter projects and all was going well, I was putting my exhaust back on till I get the torque cones in,and that is when i droped one of the exhaust bolts I heard it hit the motor and now I can`t find it. . I moved the bike foward and back but it didn`t drop out. question is,is their any way it could of gottin in to the primary case,if so I guess that will cause a lot of damage
Old Dec 3, 2008 | 05:22 PM
sniper77's Avatar
sniper77
No way for it to fall inside the motor. If you were working on the back cylinder it is probably hiding behind one of the fins on the tranny. If it was the front cylinder just take off the voltage regulator and it will probably fall out.
Good luck!
Old Dec 3, 2008 | 05:28 PM
jjwin98's Avatar
jjwin98
well at least I know it cant get into the motor or primary. Thanks
Old Dec 3, 2008 | 05:29 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
The primary is basically an enclosed chain case, the only things coming out of the inner case is the shaft from tranny to clutch basket and the shift shaft linkage. I've seen stuff bounce on the swingarm right behind the tranny, under the starter or even land on a inner primary casting web. Good luck.
Old Dec 3, 2008 | 05:42 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Well I just had a mysterious torx screw appear under my bike and can't figure out where it came from. If it was off my old timer cover it has been riding in my engine/frame for 2 years.
Old Dec 3, 2008 | 06:54 PM
BB_Stackr_86's Avatar
BB_Stackr_86
6th Gear
Default Get one
I dropped a bolt into a place where I couldn't see it, but ran a telescoping magnetic stick in all those places, and picked it up from in between the primary & tranny I think .
$5.00 at Sears or any parts store.
Joe
Old Dec 3, 2008 | 07:01 PM
08fxdf43202's Avatar
08fxdf43202
Look under the starter.
Old Dec 3, 2008 | 08:19 PM
Bobber S's Avatar
Bobber S
Same thing happened to me... I Dropped the nut and it just vanished! So I started the bike and drove it to the end of the driveway. Stopped the bike and presto ! The nut was sitting on the edge of the street.
What pissed me off is I never would have been working with the nut if the stealer had bolted my exaust back on after doing my winter mods. That right, I picked up the bike with pipes attached at the rear, but O2 sensor and manifold bolts not even connected. I discovered this after I rode the bike for about 10 miles this spring. First when the engine light came on I realized the O2 sensor was not connected so I connected and thought problem solved. 10 miles later I realized the pipe was not even connected to the manifold, and nuts were still sitting on the engine block ! Next time I'll do my own mods and put the bike back together myself.
Lucky I didn't burn a piston.
Old Dec 3, 2008 | 08:45 PM
cruzin papa's Avatar
cruzin papa
I dropped a nut once and nine months later a son appeared. Just kidding but I did drop one of the ferrels that are one the cables while changing my hand grips in the grass. Took and my son about an hour to find it.
Old Dec 3, 2008 | 08:54 PM
anubisss's Avatar
anubisss
Always keep a couple of extras for when this happens. Rarely do I find it...
Hey Man
EVO
14
Oct 16, 2018 07:08 AM
berndog
Shovelhead
Apr 13, 2012 04:24 PM
Beauregard
Jun 7, 2009 06:23 PM
lrntowrench
Feb 12, 2008 11:04 AM
fxr85
Mar 26, 2006 01:32 PM
