NEED HELP BAD, tranny leak?...
Old Jan 23, 2009 | 07:49 PM
jordanball33's Avatar
jordanball33
Default NEED HELP BAD, tranny leak?...
i was on my way home from college today and about half way of a 2 hour ride, i noticed that there was some fluid leaking out of the side on my transmission, i have forward controls and it looks like the fluid was coming out of the plug thing where the stock shifter went. below i have a picture of where i think the fluid is coming from. can i tighten anythign up? or what do you think is wrong, please help or ill have to take it to the stealer.
Old Jan 23, 2009 | 08:33 PM
mud's Avatar
mud
jordan, pull off the outer Primary cover
and replace the gasket that seals that hole.
mud
Old Jan 23, 2009 | 08:47 PM
paul s's Avatar
paul s
Is your warranty still good?
Old Jan 23, 2009 | 10:44 PM
chad peterson's Avatar
chad peterson
It's an easy fix man! Just like mudpuddle said, take your outer primary off & it's just a little round gasket that comes with one sticky side to set it on then put your outer primary back on!
Old Jan 23, 2009 | 11:26 PM
JerseyDevil's Avatar
JerseyDevil
+1 on what Mud and Chad said, I believes it called a tower gasket.
63869-06 GASKET, TOWER (Gasket where shifter shaft goes through on mids)
That part number is for and 06 but I believe the primary from 06-08 is the same. Cost like $1.50.
Old Jan 23, 2009 | 11:35 PM
EVO80's Avatar
EVO80
As the others have said there a gasket that seals the hole - easy to replace once you remove the outer primary cover. I would recommend getting a primary gasket (goes between the inner and outer primary covers) and not reusing the one thats there or you may end up with another leak. If you don't have a manual let me know and I'll shoot you off the torque values and tightening sequence of the primary bolts.
Old Jan 24, 2009 | 01:51 AM
JRK5892's Avatar
JRK5892
you will also need new fluid... be sure before taking those allens off you POP them once with a punch... it will help ensure you dont strip them, or snap a bolt.... that little silver cap is where your mid control peg used to stick out of... while you ahve it all torn apary scuff that sucker up and hit it wiht some flat black heat paint... that way you done have a chrome cap in the middle of your primary! i wish i would have done that when i had mine apart!
Old Jan 24, 2009 | 09:47 AM
SuperFastGlide's Avatar
SuperFastGlide
i took my primary to napa and got a couple freeze plugs and permantlly plugged both sides , from the inside..
without a shaft going thru the tunnel i beleive the gasket will always eventually slip from between the covers and seep oil out the shifter hole..
jus my 2 cents..
Deerslayer011
Jun 26, 2016 08:48 AM
Northern Cowboy
Jun 14, 2015 04:17 PM
msamarah86
Jun 25, 2011 01:43 PM
SuperglideGirl
Jul 31, 2010 12:16 PM
Handycam
May 6, 2009 06:30 PM
