SERT vs PC-V
Old Feb 8, 2009 | 08:52 AM
doxbike's Avatar
doxbike
Default SERT vs PC-V
First, where does the PC-V fit? Hope it's not in the "V" (wishbone) under the seat, 'cuz I just filled that up with a 3 circuit fuse block
http://easternbeaver.com/Main/Produc...3_circuit.html.
I used the unswitched lead for a power socket, 1 switched for the Stebel horn (& yes it does matter which horn wire goes where-just a hum if you get them wrong) and 1 switched lead for an SAE connector.
Sorry, back to my next question. Has anyone used the PC-V and then changed to the SERT? any major difference?
I'm being told that the PC-V can only add fuel, not take it away and that there are some spots where fuel need to be taken away. I find that hard to believe with a 14.7:1 AFR from the factory.
And does the PC-V have the capability to adjust the timing?
I'm still trying to decide which way to go and any input would be helpful.
TIA
Old Feb 8, 2009 | 09:24 AM
jstreet0204's Avatar
jstreet0204
14.7:1 will not be the commanded a/f under wide open throttle (WOT). That is closed loop fuel settings. WOT commanded a/f settings will be closer to 12.5:1
Old Feb 8, 2009 | 09:28 AM
Gary7's Avatar
Gary7
Also, for 2009 Harley richened things up a bit. The TC96 is running 14.5 to 14.6 from the factory for 09. (I think they finally wised up and realized this engine just could not handle 14.7 from a rideability standpoint.)
Old Feb 8, 2009 | 09:33 AM
jstreet0204
Yeah, I've read that too. 14.7 is ideal in a water cooled engine, but with the heat of these air cooled motors it just too lean.
Old Feb 8, 2009 | 10:41 AM
Pythagrean's Avatar
Pythagrean
My PC-V fit right underneath the seat. It took a little bit straightening up the wires, but it fits perfectly under there.
Old Feb 8, 2009 | 11:50 AM
jstreet0204
For the PC V
Harley Davidson Units Also Include:
Fuel and Timing control
Rev Xtend
“Warm Up” fuel adjustment (unit reads engine temp and allows fuel/timing adjustments based on it)
Software will display J1850 data from bikes’ stock ECU (this is data such as temp, fuel pulse width, timing advance, spark knock, etc.)
http://www.powercommander.com/powerc...formation.aspx
It looks like a pretty cool setup if you plan to do alot with the engine. I like the expandable modules like autotune and anolog inputs. That is very similar to the tuner I use on my supercharge mustang.
Old Feb 8, 2009 | 12:02 PM
drhooligan's Avatar
drhooligan
Does anyone know if the PC-V can be used on pre '09 EFI bikes. Really like the auto tune capability without replacing the bikes original ECM.
Old Feb 8, 2009 | 12:06 PM
bberck's Avatar
bberck
Power Commander is only currently supporting them for the 09's.
Fuel Moto is supporting them for 07-09 models. I have the PCV on my 08 and the bike runs great.
Old Feb 8, 2009 | 04:02 PM
drhooligan's Avatar
drhooligan
Good to hear that the PC-V works on an '08, should then work on an '07 I'm guessing. Does this also mean that the Auto Tune accessory for the PC-V would work on the 07/08 bikes. I've got an '07 Dyna with a decent running tune but would love to have that auto tune module.
Old Feb 8, 2009 | 04:53 PM
drhooligan's Avatar
drhooligan
Fuel Moto's web site shows the PC V and Auto Tune for the '07/08 HD bikes. Great! Now I can try and sell the PCIII that I just bought from them 4 months ago.
87gtNOS
13
Aug 3, 2023 07:04 AM
jshull
Aug 31, 2010 06:08 PM
Cheiron
Aug 20, 2010 11:05 AM
Puttnutt24
Jun 13, 2010 02:25 PM
07JakeelwoodHD
Mar 25, 2009 06:49 PM
