Front end goes clunk?
Old Mar 11, 2009 | 06:51 PM
Dyna-Asa's Avatar
Dyna-Asa
Default Front end goes clunk?
I've put about a 1000 miles on my 07 Dyna SG since i bought a month ago(1200 mile on the bike) and I've noticed that the front end makes a "clunk" sound when i hit small bumps in the road at slow speeds (less than 40mph) is this common? or should i have it checked out?
Thanx
-Asa
Old Mar 11, 2009 | 06:52 PM
anubisss's Avatar
anubisss
Either the steering head is loose or the tank is loose, or both. I remember someone having the steering head tightened and it still did it. Took them a while to check the tank mounting bolts.
Old Mar 11, 2009 | 06:58 PM
RAWHIDE07's Avatar
RAWHIDE07
HD knows about this problem and covers it under warranty,it's just a new washer on the steering head along with a re-torque,you can do it yourself easily.
Old Mar 11, 2009 | 07:04 PM
Gwjvw's Avatar
Gwjvw
Its the sterring head i just fixed one about 2 months ago. By guessing on what your saying without seeing it! Put the front end in the air and check it out real quik!
Dyna-Asa's Avatar
Dyna-Asa
cool on my next day off I'll take it to my dealer for the fix
thanx
-Asa
Old Mar 11, 2009 | 07:06 PM
Dyna-Asa's Avatar
Dyna-Asa
I don't have a motorcycle jack yet
Old Mar 11, 2009 | 07:46 PM
bberck's Avatar
bberck
Most likely is the steering head but check the tank bolts before taking it in. I did some work on mine once and was making the same sound and ended up being the front tank bolt wasnt completely tight.
Old Mar 11, 2009 | 07:52 PM
mynzbtr1's Avatar
mynzbtr1
My fat bob made the same noise, it was the front tank bolt
Old Mar 11, 2009 | 07:55 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
+1 on the tank bolts and the steering head bolt. Before retightening the steering head bolt, loosen the pinch screws on the lower tree, thump the lower tree with a rubber mallet to free the tubes. After retightening the screw, tighten the lower pinch screws.
Old Mar 11, 2009 | 08:13 PM
Goddahavit's Avatar
Goddahavit
make sure you take a tsb bulletin with you I had 2 dealers look at me cross eyed, with the paper, finally 1 read it said yep got it in stock, and fixed it, been quiet since...
Im not sure of the bulletin any more, but search this site on clunk should turn it up.
