more noise
Old May 6, 2009 | 07:29 PM
lhcstreetbob's Avatar
lhcstreetbob
Default more noise
ok i posted a thread a few days ago about a noise i was hearing coming from the engine i did a search and found a little some guys said to put some lucas oil additive in .i guess it sounds like a sewing machine ive checked everything that i thought could be loose and cant find anything. i paln on changing over to synthetic this weekend will this help the noisy engine?
Old May 6, 2009 | 07:59 PM
Topspin's Avatar
Topspin
Get pipes loud enough so you don't hear the sewing machine under the windshield.
Old May 6, 2009 | 08:04 PM
SuperFastGlide's Avatar
SuperFastGlide
actually it will be a little noisier with synth oil, its a motor, gonna make some mechanical noise, normal..
Old May 6, 2009 | 08:29 PM
archergodwin's Avatar
archergodwin
When I changed over to HD syn3 at the 1K, it sounded like I had marbles in the case. Changed that out quick... run Mobil1-vtwin 20/50 now. Motor sounds fine.
Old May 6, 2009 | 08:53 PM
ackman1968's Avatar
ackman1968
It's a motor you are basically sitting on. It's amazing how much noise they make, you'd hear a lot more in your cage if it weren't for the sheet metal.
Old May 6, 2009 | 09:42 PM
2002fxdp's Avatar
2002fxdp
yea the syn. makes it louder.
sewing machine aint bad.
its the ticking that gets me.
billet rocker boxes, new gear drive cams and lifters and belt drive and now mine sounds like a sewing machine.
you may want to try something else.........................
Old May 6, 2009 | 10:34 PM
lhcstreetbob
ok i was just wondering i never noticed it before it all started pretty recently. i just dont to foul up my motor.
Old May 6, 2009 | 10:37 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Dino oil like HD360 will abate noise better than synthetic. But the noise from syn oils is not an indication of wear. If you are looking for a good dino oil try Brad Penn 20w50 high performance at www.bradpennracing.com
Old May 6, 2009 | 10:48 PM
lhcstreetbob
cool thanks man i might try that anybody have any luck with the severe gear oil from amsoil the guy at the indy swears by it?
Old May 7, 2009 | 03:08 AM
jmpancoast's Avatar
jmpancoast
I ran HD dino in my 06 FXDI the first 12,000 miles. All the sounds of the bike sounded normal to me until the windshield was on (which I rarely use). The bike sounded completely different and I did hear the sewing machine.
I now have several thousand miles running the HD Syn and hadn't noticed any difference in the way the bike sounded. I also had not used the windshield in over a year. Last weekend, I used the windshield for a couple hundred mile trip. I was amazed how much quieter the motor was. No more sewing machine affect echoing off the shield.
I don't have a clue what the inside of the motor looks like, or how much wear has occurred on the internal parts. But the motor sounds as though it is purring instead of clanking and rattling.
