pc V afterwash
Old May 15, 2009 | 09:20 PM
maddghost's Avatar
maddghost
Default pc V afterwash
I washed and waxed the bob today and had the seat off maybe the pcV got a little wet,I tried to dry it off and when I took her out to the wind to air out she reacts fine at normal throttle but anything above half throttle and it's like she's hesitating! Will it dry off and go away or will I be calling jamie at fuel moto to find out what is up with that? She never haesitated before!!
Old May 15, 2009 | 09:22 PM
archergodwin's Avatar
archergodwin
Unplug the PCV and dry out the connections.
.... and don't wash the bike with the seat off again...
While you have it apart, apply some dielectric grease in the connector. It will help keep water out.
Old May 15, 2009 | 09:23 PM
joe.1955's Avatar
joe.1955
Connectors probably got water in them. Remove them , dry them off and add dielectric grease to minimize water intrusion.
Old May 15, 2009 | 09:26 PM
rjmac53's Avatar
rjmac53
let us know if you get it fixed...
Old May 15, 2009 | 11:13 PM
maddghost's Avatar
maddghost
.........so this hads been known to happen, ok thanks ,tomorrow when it's light out if it ain't raining!
Old May 15, 2009 | 11:55 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Try using a hair dryer to dry it out.
Old May 16, 2009 | 06:44 AM
rounder's Avatar
rounder
you may also want to put it in a ziploc bag to help keep out moisture when you reinstall it.
Old May 16, 2009 | 08:15 AM
Cornhusker's Avatar
Cornhusker
Dielectric grease in all connections of the PC V should be used. That should take care of your problem. I always remove the seat when I wash the bike and have never had a problem with my PCIII and water intrusion.
Old May 16, 2009 | 09:21 AM
ratt196635's Avatar
ratt196635
i used Dielectric grease on all my conections including those on the unit and have not had anyproblems with washing my bike with the seat off.
Old May 17, 2009 | 01:58 PM
maddghost's Avatar
maddghost
O hell guys I'm really in it now! I took apart every connector from the pcV and only found water in the pcV black connector The one that hooks up to the stock harness. So I'm al happy , i chase out the water and stand there with hair dryer for about 15 minutes on and off until I think it's dry and smear dielectric grease on both sides all the pins and alll the holes and around the rubber gasket , zip tie it all together start her up seams fine. The power light on the pcV is green but the status light is red and intermittent. I get a few blocks from home she has full power but begins to cough and dies out with a loud backfire. I get anothe r2 blocks dies again and won't start. So I wait a couple of minutes she starts I get home and put the bike away! What is going on here? too much grease? I am so FUGGED UP!
2014streetglide
Fuel Moto / Jackpot Mufflers
Jun 8, 2011 07:40 PM
Canuckle
Jun 8, 2011 02:19 PM
WIDERGLIDER
Apr 12, 2011 03:55 PM
maddghost
Oct 17, 2009 04:22 PM
maddghost
May 20, 2009 08:46 PM
