Installing Progressives?
Old Jun 24, 2009 | 07:52 PM
archergodwin's Avatar
archergodwin
If you don't have lift, it will be easier if you have a friend.
Depending on the year of the bike, the upper "nut" is 35-40ft/lb. The upper "bolt" 75-80.
Lower bolt(s) is 35-40ft/lbs
Old Jun 24, 2009 | 09:32 PM
MNrider's Avatar
MNrider
I swapped stocks to air to stocks to air to stocks. The last time I used a floor Jack and it was a breeze. The other times I used the jiffy stand and it was a biatch. Like Joe said, stretch really good if you use the jiffy and muscle.
Old Jul 28, 2009 | 09:20 PM
nathan.edwards's Avatar
nathan.edwards
Stage I
lower bolt 30-40 ft-lbs upper 75-85 ft-lbs or both upper and lower bots at 30-40 ft-lbs? Both are said in this thread, which is right for 2009 fat bob?
Old Jul 29, 2009 | 12:11 AM
CaptGoodvibes's Avatar
CaptGoodvibes
What does your service manual say?
Old Jul 29, 2009 | 03:10 AM
Mixter's Avatar
Mixter
I just did the exact same shock swap on my 08 fat bob....according to what I was able to find out if the top bolt is an Acorn then it's 30-40lbs....if it's not an acorn then it's 75-85lbs. I am pretty sure all of the Fat bobs have the acorn...at least on the 08's.
zeke7142003
Apr 19, 2018 08:42 AM
Twinrider
Jan 27, 2017 08:30 AM
ZeroFiveFour
Feb 26, 2011 10:15 AM
Harley43147
Nov 18, 2009 11:52 AM
08FXDC
Mar 8, 2009 10:25 AM
