Thunderheader exhaust installation help!
Old Aug 24, 2009 | 11:37 PM
dynafan68's Avatar
dynafan68
Originally Posted by SC-Longhair
The clutch release cover is the one marked "SIX SPEED" on your bike.
You may want to buy a service manual for your bike.
Ball-end allen wrench is necessary to get in there and loosen those bolts.
Disassemble the brake rod from the controls so you can drop it down for some clearance. A small cotter pin will release the rod.
direct link to LARGE photo of install sheet:
http://i64.photobucket.com/albums/h1...e/DSC02923.jpg
http://i64.photobucket.com/albums/h1...e/DSC02924.jpg
Thanks a lot!!!!!
Great photos/info, If the TH instruction can be like this way...
Old Aug 24, 2009 | 11:42 PM
dynafan68's Avatar
dynafan68
Originally Posted by bucket13
Do yourself a HUGE favor and buy a service manual. Read the TH install sheet and then refer to the service manual and look up what you do not understand or are not familiar with. This is the method I used. I also searched the dyna forum for anything related to Thunderheader. There are alot of helpful posts out there.
Good Luck!
Already order the HD service manual! also the parts manual.
Old Aug 25, 2009 | 12:31 AM
kk6pg's Avatar
kk6pg
After you get the bracket on, the fun is just beginning
Do the rear first and run the flange nuts up 2 threads. Chain the bike to the floor, put your left foot on the rear pipe, pull the front with all your strength and spring it on. Just before you get your fingers pinched between the head pipe and the head, make sure the flange is in place. Then let loose of the head pipe and get your fingers out of there before it slams home. Stick a couple of nuts on the front pipe.
Then you can run for the box of bandaids you forgot to bring with you, and while you're in the medicine cabinet, grab the bottle of pain killers and down em. You can finish tightening everything up tomorrow when you come down off the pills
Old Aug 25, 2009 | 01:00 AM
dynafan68's Avatar
dynafan68
after reading this...
sounds horrible story...
Old Aug 25, 2009 | 01:16 AM
kk6pg's Avatar
kk6pg
Look at the bright side,
Once you get it done, with any luck, you wont have to do it again.
Or at least the second time it will get easier.
Pay attention, be patient, and whatever you do, dont get frustrated when it doesnt go as easy as you think it ought to.
Old Aug 25, 2009 | 01:48 AM
dynafan68's Avatar
dynafan68
I'll put on a pair of glove first! :P
Cleetussnow
EVO
Feb 27, 2012 02:37 PM
timeout
Sep 30, 2011 03:53 PM
timebandit60185
Mar 19, 2009 08:54 AM
Dsanchez
Mar 4, 2006 02:47 AM
HDF Tech
Sep 14, 2005 09:45 AM
