battery is dead
Old Sep 1, 2009 | 03:36 PM
ionate's Avatar
ionate
Default battery is dead
I left my ignition turned on today during my lunch break. Ok, it was more than a break - it was for about 2 hours. Anyway, now I have a dead battery and was forced to drive my cage back to work.
What is the proper procedure for charging the battery back up? I have a battery charger that I use for my vehicles, but I wasn't sure if I could just hook it up as it is or if there is anything special I need to do?
Thanks in advance...
Old Sep 1, 2009 | 04:02 PM
thedonthere's Avatar
thedonthere
I would trickle charge it overnight
Old Sep 1, 2009 | 04:05 PM
mp's Avatar
mp
You need a one amp charger, preferably one that monitors the charge. Most car chargers are too big for the small motorcycle battery. If you have just a straight charger, leave it on for at least 12 hours.
Old Sep 1, 2009 | 04:07 PM
JRK5892's Avatar
JRK5892
+1 trickle charge over night
Old Sep 1, 2009 | 06:00 PM
maddghost's Avatar
maddghost
I wonder what would happen if you get a boost then ride for a good hour or so and see if it starts up. But you def need a trickle charger sooner or later. 40$ or so.
PS don't feel bad lots of us have done that ,last year I called my local service tek and she just had it changed out for me under warrenty,after I pulled exactly your stunt! I boosted mine with the car (ignition off) and rode it in to save the tow charge! Lucky I guess.
Old Sep 1, 2009 | 06:03 PM
xxxflhrci's Avatar
xxxflhrci
Your charger probably has a 2 amp slow charge setting. It will charge your battery just fine and not harm it.
Old Sep 1, 2009 | 07:08 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
A 19 amp battery with 0 % charge, according to my service manual, charge times (approx.):
3 amp charger=6hours and 40 minutes
6 amp charger=3 hours 20 minutes
I would get the battery up to 12 volts then throw a battery tender plus on it and see what you get, the plus tenders have to see some voltage before they start working.
Old Sep 1, 2009 | 08:40 PM
OsoFat's Avatar
OsoFat
I'll admit to leaving my ignition on over night. Yeah, stupid. Trickle charger wouldn't charge it. 2 amp car charger wouldn't charge it. 10 amp car charger got it going, but the batter was shot. It would hold a charge for a couple of days, but left me stranded, once. I had to buy a new one. Yeah, stupid.
Old Sep 2, 2009 | 08:58 AM
HarleypsychRN's Avatar
HarleypsychRN
Agree with the trickle charger...It should charge it overnight without a problem...if it's still dead after that you got a problem
Old Sep 2, 2009 | 09:52 PM
AFHuey's Avatar
AFHuey
Don't forget to blue loctite them screws back in the terminals when you are done....I learned that lesson the hard way. Couldn't figure out why my bike wasn't charging back up.....loose ground wire.
reeves1238
Electrical/Lighting/Alarm
25
Apr 23, 2016 01:42 PM
Asclepeus
Aug 11, 2012 08:21 PM
All Aces
Dec 20, 2011 05:55 PM
Greasemonkey1
Jul 28, 2010 10:38 PM
Demonsmasher
Mar 24, 2008 09:04 PM
