So what you're saying is that the motorcycles they ride to work everyday are not really running properly .....o-kay.
I'll let him answer about what he's saying.
But what I think he's suggesting is that this doesn't seem to make sense, "Starting in '07 or '08 the computer doesn't need a tuner for any stage of upgrade...because the ECM adjusts within 15 minutes to the proper parameters." If that's true, and it may be, I would like to understand it more. My current understanding is that yes, while the ECM can adapt some changing inputs, and will adjust accordingly, it will only do so to a limited extent. For example, the stock O2 sensors have a relatively narrow range. If the AFR is outside that range, the ECM can't adjust. So I can't see running something like a 113" build with open pipes and doing nothing to the ECM at all.
TTS or SERT is money well spent....either way, it needs to be tuned on a DYNO by somebody who knows what they are doing.
I have the download and PC III. The TTS or SERT is better becasue it has more adjustability.
As far as the download, it also raises your redline, in addition to a more agressive ignition curve and A/F ratio. The PC III jsut allowed for more fine tuning.
Essentialy, yes!
Originally Posted by 98glider
To confusing for me If and when I do buy a new bike what am I suppose to buy to make her run good? Thanks
A quality tuner! Look, all these bikes run very lean from the factory. HD's fault?? No, you can thank the EPA! This is why at a stop light, you're right thigh feels like it wants to burst into flames, that leanness equates a hot running motor, which we all know, heat is a killer to a motor. It's also a matter of time before the air cooled V Twin is history as it will not be able to with stand EPA requirements.
In bold, is correct! It makes no sense. The 02's ARE narrow band, which is not enough to compensate, if at all! If you do upgrades as he suggested with no ECM changes, not only would it run shitty, but over time you WILL fry the pistons.
I guess some of you don't know the closed loop, narrow band O2 sensor system of '06 was changed to the wide band, open loop system in '07.
That's fine, I'm sure no damage will be done by opting to go with a tuner and a few hundred dollars worth of dyno time that you really don't need.
My understanding of the stock ECM is that it does self adjust to minor changes to the A/C and Exhaust system. The O2 sensors keep the AFR at 14.7 regardless of whether or not you have the Stage one down load.
It is against federal law for a dealer to alter the AFR.
Amen. The sensors constantly measure afr and adjust mixture in real-time to maintain 14.7:1. If you add an IED, you can reduce that to approximatley 14:1 depending on which you choose. Bolt on any pipes you want...no tuner needed. Lots of guys wasting lots of money on tuners that do nothing in closed-loop mode.
Not sure if this would apply to major rebuild impact, but entirely likely.
07 FXD---Rode to Sturgis in 95+ deg weather at legal or slightly above the posted limit, then to Bonnyville, Reno, San Fran, and home to BC ----SE air Cleaner, Supertrapp 2/1 and Xied's, mileage about 200 miles before light came on----bike ran exceptionally well.
06 Bob--same trip, wifes bike, ridden a little faster than mine on occasion, Aftermarket open aircleaner with SE filter, V&H 2/1 pipes, and 06 Ied's the first model--bike ran better than mine mileage wise.
Taking heads off this winter to check for any "signs" of concern---do not expect any.
