@*%&@## Alarm!!
Old Dec 3, 2009 | 04:10 AM
Derv's Avatar
Derv
Default @*%&@## Alarm!!
I'm doing some work on my '02 Dyna which involves wiring so I've disconnected the battery. I disabled the alarm before starting but as soon as the battery was disconncted it fired off - it's very loud in my garage! I tried putting it into service mode which worked ok but about 3 hours later the damned thing started off again.
The manual tells me how to re-instate the alarm after the battery's been disconnected but not how to disable it before disconnection.........Anybody any idea please before the neighbours have an ASBO slapped on me?
Derv
Old Dec 3, 2009 | 05:01 AM
08fxdf43202's Avatar
08fxdf43202
I unplug my factory siren and lay it on the bench.
Old Dec 3, 2009 | 07:53 AM
Derv's Avatar
Derv
Yep.......tried that and as soon as I disconnect the plug it goes off all by itself - must have an internal battery. Driving me nutz now!
Derv
Old Dec 3, 2009 | 10:57 AM
MidnitEvil's Avatar
MidnitEvil
Weird. I have an 02 WG and have never had an issue with my factory alarm going off while working on the bike. Can you remove the internal battery?
Old Dec 3, 2009 | 03:01 PM
08fxdf43202
Yes, the siren has a re-chargeable 9 volt battery that is removeable.
My siren doesn't go off when it's on the bench.
Old Dec 3, 2009 | 03:11 PM
HDRusty's Avatar
HDRusty
use a 5 pound hammer and swing from above your head. That should sort out the alarm problem
Old Dec 3, 2009 | 03:24 PM
maddghost's Avatar
maddghost
My manual says approach the bike with key fob present. turn ignition switch to on. after the alarm disarms itself then you pull the battery cable. That worked for me ,but the batt. was only off for 1 hour or so. Did you try that?
Old Dec 3, 2009 | 06:35 PM
Derv's Avatar
Derv
HD rusty - don't tempt me, it was going a in a bucket of water this afternoon, if it hadn't gone off that's definitely where it would have ended up!
All is quiet now - thanks for all the replies guys, I wasn't aware you could get at the rechargable battery in the siren unit, there doesn't appear to be any way into it. I'll have another look but will leave it 'til tomorrow in case it kicks off again - it's 12-30 am here! I'm not too popular with my neighbours as it is - it's the Screamin' Eagle pipes that did it
I eventually got it to not go off, but not sure how I did it - just disabled the alarm as normal and pulled the neg leads - something I'd already tried several times. I've got to admit though that alarms don't like me, I've had some quite bad times with them - think I must have been a bike thief in a past life...........it's karma!
Derv
Old Dec 3, 2009 | 07:50 PM
Hickey's Avatar
Hickey
I just pull the maxi fuse, works great, you hear the alarm die off as you pull the plug. Its scary how easy it is to disarm the alarm (well, the siren at least).
Rocker_Dan
Dec 21, 2013 11:32 PM
JayOhh
Apr 17, 2013 12:02 PM
HDUK
Jul 2, 2012 12:59 AM
jb27
Mar 12, 2012 04:45 PM
rattlebones
Dec 10, 2009 05:30 PM
