How do I get rid of clutch "safety" button on 07 SB controls?
Old Dec 8, 2009 | 06:03 PM
Muddyape's Avatar
Muddyape
Default How do I get rid of clutch "safety" button on 07 SB controls?
changing levers out to Joker Machine stuff and going with basic clutch lever with no button in the lever. anyone know how to rewire/override it?
Old Dec 8, 2009 | 06:22 PM
ghostrider69's Avatar
ghostrider69
If I were a betting man I would say just find the wires that go to the switch and wire them together.
Old Dec 8, 2009 | 06:25 PM
maddghost's Avatar
maddghost
Sorry I can't help you there muddyape,but I want to ask ghostrider69 to never - ever change his avatar ! pleeeeease?!!!
Old Dec 8, 2009 | 08:07 PM
08fxdf43202's Avatar
08fxdf43202
Although I don't think it's a real good idea to by pass the clutch SAFETY switch... the cleanest way to do this would be to:
1) Locate & disconnect the left hand control wiring plug from under the tank, which is stuffed down the back bone.
2) On the male side of the plug (hand control side) remove pin #7-the red/black wire and pin #8-the black wire.
3) Solder a jumper wire to the but end of the pins.
4) Re-insert the pins into the plug and re-assemble the plug.
5) Put the trans into 1st, pull the clutch & hit the starter...
Adding a jumper like this would allow an easy way to restore the clutch SAFETY switch.
Old Dec 8, 2009 | 08:30 PM
Harlie Rider's Avatar
Harlie Rider
Hi Mud, I pinched those wires on my Bob as I was changing grips in a hurry. I
looked for hours trying to find out what I had done. The key light would come
on and stay on. Also, the bike wouldn't start unless it was in neutral. I finally
traced it down to the wires to the clutch switch where I had pinched them. I
checked the manual and the wires are only a Black and a Black/Red stripe. I
believe the black is a ground and the one with the Red stripe goes into a
connector.
If you think about how the clutch switch works, when the lever is engaged, there
is either contact or not, that is, the plunger pushed in and the switch makes contact
or breaks contact. This was my dilemma, I just wired it back and left it. I do not
think it would hurt to disconnect it, but I never did.
Old Dec 8, 2009 | 08:33 PM
Muddyape's Avatar
Muddyape
Thanks, So I cant start in Neutral anymore? Guess I never got the point of the switch. But if im jumping it, isnt it just like the clutch is engaged? I always start in neutral, should still be able to?
Old Dec 8, 2009 | 08:41 PM
Yasky1997's Avatar
Yasky1997
If the switch is not activated by the clutch lever, the bike will only start in neutral. If you jump the switch either in the frame behind the neck or in the switch housing itself, the bike will start anytime (in gear out of gear or with or without the clutch pulled in)
Old Dec 8, 2009 | 10:00 PM
SuperFastGlide's Avatar
SuperFastGlide
i have after market levers... i just always start my bike in nuetral now.. no biggie, plus its a little easier on the starter motor
davidw221
Electrical/Lighting/Alarm
Dec 20, 2014 09:14 PM
maxboxa
Apr 30, 2013 05:06 PM
jlasoftail
Aug 7, 2011 02:42 PM
streetfighter06
Sep 17, 2010 01:38 PM
MidnightRider
Oct 18, 2007 11:45 PM
