Sears red jack modification
Old Jan 2, 2011 | 04:23 PM
  #231
lo-rider's Avatar
lo-rider
Default phase II
For my phase II mod, by clamping each channel in a drill press, I was able to easily drift a tight-fitting clearance hole (for the cross-tube) right up against the underside of the channel's top. These tubes were then welded both @ their ends (where they come up against the inside of the channel wall) & also where they pass through the channels' inner walls. It takes all the cantilever (bending) load off the bolts (bolts don't like to bend), leaving them w/ simple shear loads, for which they are well oversize. This virtually eliminates all tendency for the channels to "tip" downward, as the load is applied, and keeps them in plane.
Old Jan 2, 2011 | 05:26 PM
  #232
tarheelrdr's Avatar
tarheelrdr
Originally Posted by SC-Longhair
You tried using the modded jack under an Ultra? Yeah, this mod would probably need the support bar to be reinstalled to lift that bike. No way I would trust lifting that weight to 4 bolts, even grade 8. The WG should be find without it.
For the record, I'm fairly certain my 07 wg front end comes up first before the back end so I don't think it's a weight problem regarding your ultra.
I put the jack back to its original position for the Ultra. But without the support, the back end was still way lower than the front. Then I used my other Sears red jack without any mods and it worked good as usual.
Tarheelrdr
Old Jan 2, 2011 | 07:02 PM
  #233
larfxdc's Avatar
larfxdc
Stage IV
thanks for the info.. great mod.. i just did it and it works perfect. nice and stable..
Old Apr 4, 2011 | 08:28 PM
  #234
dtone72rss's Avatar
dtone72rss
Doping this tomorrow
Old Apr 4, 2011 | 08:45 PM
  #235
desertrideryz's Avatar
desertrideryz
Great info. thanks!
Old Apr 4, 2011 | 11:19 PM
  #236
Matthew Johnson's Avatar
Matthew Johnson
I am definitely going to steal this one from you. Ive had that jack for years and am ashamed that my bitching has never evolved into something like this. thanks Vic
Old Apr 5, 2011 | 10:19 AM
  #237
DSnoopy's Avatar
DSnoopy
Okay, the first video is not loading in the thread. Where is the info on the jack mod?
Old Apr 5, 2011 | 10:24 AM
  #238
SC-Longhair's Avatar
SC-Longhair
You can search youtube for my profile. My name on there is scvic2006
I'd also suggest clearing your temp internet files, cookies, etc and reloading the page.
Old Apr 5, 2011 | 10:46 AM
  #239
DSnoopy's Avatar
DSnoopy
LOL- Thanks!
Old Apr 5, 2011 | 10:53 AM
  #240
The Gecko's Avatar
The Gecko
Awesome video! Thanks man!!
