Sears red jack modification
Old Dec 31, 2010 | 07:51 PM
  #221
Slowride2's Avatar
Slowride2
I don't think the lift would go all the way down if you had a center post with the pads moved to the outside.
Old Jan 1, 2011 | 07:14 AM
  #222
SC-Longhair's Avatar
SC-Longhair
Originally Posted by King_O_Road
It was just to use as handles, to pick the thing up and put in a truck... friends borrowing it and all... and to make one cut vs. two...
That makes sense, as loading it into anything waist high can be a little cumbersome. Good idea.
Old Jan 1, 2011 | 08:22 AM
  #223
m.breen's Avatar
m.breen
Ill have to see if that applies to my Costco, Black Jack. I removed the wheels on the jack to give it some clearance but, I like having the wheels on.
Old Jan 1, 2011 | 12:36 PM
  #224
NoLongerAmember's Avatar
NoLongerAmember
It should, lo-rider welded a bar back into place. Post 130
https://www.hdforums.com/forum/7110178-post130.html
CB
Old Jan 2, 2011 | 01:57 AM
  #225
lo-rider's Avatar
lo-rider
Default phase II
On my phase II lift mod (earlier in this thread) I showed how I welded a new spreader bar to support the cantilever load. It is not centered vertically, but roughly flush w/ top of channels (touching inside top). Very simple & easy, and does not interfere w/ fully lowering.
Old Jan 2, 2011 | 07:38 AM
  #226
armyglide's Avatar
armyglide
Great idea! That will be my Saturday project.
Old Jan 2, 2011 | 09:14 AM
  #227
reesestewww's Avatar
reesestewww
Today is Sunday. Haha.
How the hell did I miss this thread? That's the jack I have and what a pia it is in it's stock form. Thanks Vic for the vid, great work!
Old Jan 2, 2011 | 09:41 AM
  #228
SC-Longhair
I dunno, how did you miss this thread? lol
Hope it works out for you. Best wishes.
Old Jan 2, 2011 | 01:27 PM
  #229
tarheelrdr's Avatar
tarheelrdr
I did this mod also, but found it does need the spreader bar that lo-rider has installed. I have an 04 Ultra Classic which is about 900 lbs. and it doesn't lift the rear as soon as the front. It actually slid back a little before I figured out what the problem was. I have two of the jacks, one I keep at work, the other at home. The only problem is making sure I have the right jack for the right bike, LOL. My 03 Wide Glide is soon going to go under the knife, bumping up to a HQ 113" in the next several weeks. So the jack mod will be of great benefit.
Thanks SC- Longhair
Tarheelrdr
Old Jan 2, 2011 | 03:46 PM
  #230
SC-Longhair
Thanks SC- Longhair
Tarheelrdr
You tried using the modded jack under an Ultra? Yeah, this mod would probably need the support bar to be reinstalled to lift that bike. No way I would trust lifting that weight to 4 bolts, even grade 8. The WG should be find without it.
For the record, I'm fairly certain my 07 wg front end comes up first before the back end so I don't think it's a weight problem regarding your ultra.
