Sears red jack modification
Old Apr 3, 2012 | 05:58 AM
  #371
SC-Longhair's Avatar
SC-Longhair
It wasn't necessary.
Your frame and my frame are exactly the same underneath. Like I posted a few days ago, I used my lift to pick up a '12 Fat bob. I didn't have to do anything extra. Slide the jack under and start lifting. So, by that, your frame is the exact same as the '12 fat bob. Nothing extra was needed.
Old Apr 3, 2012 | 06:09 AM
  #372
ynots's Avatar
ynots
Originally Posted by BMyers
the notch was required so that I could get the jack far enough under the bike to pick up the opposite side. without that the front brace would hit the jiffy stand before the pads would touch the frame.
put a block under your jiffy stand then slide the jack under the bike and take a closer look.
Old Apr 4, 2012 | 09:06 AM
  #373
dreamer65's Avatar
dreamer65
have any of you guys changed out the ram for a better one?
Old Apr 4, 2012 | 09:30 AM
  #374
8541hog's Avatar
8541hog
There is no need to change it, it does everything you will ever need for your bike, why do you think you might need a "better" one?
Old Apr 4, 2012 | 11:47 AM
  #375
por2gezo's Avatar
por2gezo
Originally Posted by RicMF
I did this mod to my Harbor Freight jack yesterday, used 1/2" x 5" bolts and had to drill the holes out slightly. Made a huge difference, the lift is now so much better for a Dyna now. Awesome mod!
anyone who has done this mod to the HF jack did you notice that the lift hight is now higher because they hit the strap point loops on the base ?
or am i doing it wrong ?
Old Apr 4, 2012 | 11:57 AM
  #376
8541hog's Avatar
8541hog
Post a pic,
Old Apr 4, 2012 | 12:30 PM
  #377
BMyers's Avatar
BMyers
My sears Craftsman does the same thing. But it isnt an issue for me
Old Apr 4, 2012 | 02:17 PM
  #378
lo-rider's Avatar
lo-rider
Cut off the loops. You can strap to the frame w/ no problem.
Old Apr 9, 2012 | 10:04 AM
  #379
8541hog's Avatar
8541hog
OK, finally went out and looked at the lift, I see where you have the problem, I never noticed before because I added a 1/2" nylon spacer between the arms and pads to get a little extra width and it clears the strap loops with the spacers in there.
I would not cut the loops off, I do use them once in a while.
Old Apr 10, 2012 | 12:29 AM
  #380
por2gezo's Avatar
por2gezo
thanks for the spacer idea. i will try that
