Sears red jack modification
Old Feb 14, 2012 | 08:30 PM
  #351
Puffdaddy's Avatar
Puffdaddy
I'm wondering if the stock ride height has something to do with my issues.
I don't want to have to straddle the bike but that is the only way I can see it working.
Can any other FXDF owners chime in??
Stock heights
FXDWG - 6.2in.
FXDF - 4.9in.
Old Feb 14, 2012 | 08:42 PM
  #352
8541hog's Avatar
8541hog
Stock heights
FXDWG - 6.2in.
FXDF - 4.9in.
Not sure where you got those numbers, but that ground clearance of 6.2" has to be a mistake, the 05 WG is listed as 4.6", the 08 is listed as 5.1", and the 12 is listed as 4.2"
Either way, I can slide the lift fully under the bike with it on the stand and lift without touching the bike, stands right up as it goes up no problem.
Old Feb 14, 2012 | 09:01 PM
  #353
SC-Longhair's Avatar
SC-Longhair
Puff, do you have your shocks adjusted soft? If so, your bike will sit a hair lower. If you stiffen your rear shocks, it should raise the backend.
As far as straddling the bike, it's a horrible idea. Do us a favor. Take a photo or video with the bike on the sidestand and the jack going under the bike.
Want to see where it hits.
Also, you could try using a piece of 3/4" thick wood under the sidestand. It will stand the bike up just a bit without you having to straddle the bike.
Something else must be up like your bike being lowered or something.
Are you trying to jack the bike up from the sidestand side???
Old Feb 14, 2012 | 09:26 PM
  #354
onemyndseye's Avatar
onemyndseye
Originally Posted by Chief21
In the same boat here, too. Have read that to release the HF jack slowly you press the pedal all the way, not just a little. Read the owners manual for it on the HF web site and it states in there that is the way to operate it. Pressing it slightly is to let the jack down all the way when un loaded. I asked the question earlier and was told this mod needs to be done to the HF jack also.
If it helps, there is a coupon in this months American Iron that gets you another $40 off, making it like $66 - shipped..
Originally Posted by 2011 FXDB
I just made the choice between these the yellow HF and the red Sears jack....decided on the Sears....primary reason being concerns about the control of lowering back down the bike. With the HF there have been comments about it being a very quick drop for some. Sounds like both jacks are comparable....but that is what pushed me toward the Sears for my choice. Picked mine up for $89 on Sunday.
- Dan
Thanks for the info guys!
Old Feb 14, 2012 | 10:04 PM
  #355
Puffdaddy's Avatar
Puffdaddy
http://www.bikez.com/motorcycles/har...glide_2007.php
Just did a Google search and it was the first return.....
The Preload is set on 3
I will try to get pics of it. I really don't want to straddle it either
BTW, The jack frame is hitting the spring, not the lift pads, if that makes any difference
Already tried a 2x4 and it didn't help
Bought from the original owner with nothing more than slip-on pipes.
Mentioned that I am going from the exhaust side in post #330
Thanks for not giving up, this is driving me crazy!
Old Feb 16, 2012 | 03:42 PM
  #356
Bagger Jim's Avatar
Bagger Jim
Just saw on line they went down to 89 bucks, so I picked one up yesterday and did the mods today. Works great!
Old Feb 16, 2012 | 04:46 PM
  #357
iDodgimus's Avatar
iDodgimus
I'm having a similar issue, I have a Torin jack (pic below) and I think it's too narrow. When I position the lifting arm in front of the jiffy stand I need to add a lot of spacers to the rear arm to clear the jiffy stand bumper - that gives one arm without spacers (just on the outside of the arm) and one arm with about 1" worth of spacing... not too happy with them being so different!
After looking at the Service Manual it seems like the bumper just clips on, is that the case? I'd be happier removing it each time I put it on the lift (which wont be often) than having the arms so unevenly spaced...
Old Mar 3, 2012 | 01:58 AM
  #358
justglidin's Avatar
justglidin
Same craftsman jack, same vic mod, works great!!!
Old Mar 3, 2012 | 07:05 AM
  #359
SC-Longhair
If I understand what you're saying, your torin is in stock form? Hitting the kickstand bumper...just remove the bumper. It's just a hard plastic that slips on and off.
as for the spacers, are you spacing the frame (between the lift pad and frame rail) so the bike sits level?? That's because the frame is irregular, whence you either need A) the harley dyna lift adapters or perform the mod on your jack. It looks like it can be done.
Just so we're on the same page, can you point out which end you are referring to as the "front" and "rear" of the jack?
Old Mar 3, 2012 | 08:37 AM
  #360
Norb5150's Avatar
Norb5150
I watched this video a little late. I bought a harborfrieght aluminum lift $149 on sale and had the lift adapters laying around. How ever I still have to roll front tire onto a 2X6 due to bike being lowered. I did pay real good attention to the last few tools needed for the lift mod though
