Sears red jack modification
Old Feb 13, 2012 | 07:14 AM
  #341
SC-Longhair's Avatar
SC-Longhair
Originally Posted by R_W_B
You shouldn't have to use pads (although I do use 1/2" Ply to keep the clutch cable space more).
I realize on the Sears Red you have to cut the center brace, but you also moved the lift pads to the outside of the braces correct ?
Most of us drilled the holes a bit to a full 1/2" and bought grade 8 bolts at Ace.
Yes sir, that's correct.
Old Feb 13, 2012 | 09:48 PM
  #342
onemyndseye's Avatar
onemyndseye
Nice mod will be looking into this soon myself...
Maybe this question has been answered in the 35 pages here but I didnt see it. ... Habor Freight offers a bike lift that is 14"/1500pds for 99$. I havnt compared it much to the sears jack yet but I wondered was the mod basically the same? Any preference over the 2 that u know of?
Thanks again
Old Feb 14, 2012 | 06:09 AM
  #343
04fxdwgi's Avatar
04fxdwgi
Modified mine when I got it in 2004 after using the HD adapters and one of them seperated and almost dropped the bike off the lift. Now it locks onto the frame rails and don't need any adapters, solid as a rock, but only fits Dynas now. But I only have a Dyna and don't care about any others.
Took pads off lift and bolted these brackeys on.
Attached Thumbnails Sears red jack modification-bracket2.jpg   Sears red jack modification-bracket-1a.jpg
Old Feb 14, 2012 | 06:32 AM
  #344
2011 FXDB's Avatar
2011 FXDB
Thanks again
I just made the choice between these the yellow HF and the red Sears jack....decided on the Sears....primary reason being concerns about the control of lowering back down the bike. With the HF there have been comments about it being a very quick drop for some. Sounds like both jacks are comparable....but that is what pushed me toward the Sears for my choice. Picked mine up for $89 on Sunday.
- Dan
Old Feb 14, 2012 | 07:40 AM
  #345
Chief21's Avatar
Chief21
Thanks again
In the same boat here, too. Have read that to release the HF jack slowly you press the pedal all the way, not just a little. Read the owners manual for it on the HF web site and it states in there that is the way to operate it. Pressing it slightly is to let the jack down all the way when un loaded. I asked the question earlier and was told this mod needs to be done to the HF jack also.
If it helps, there is a coupon in this months American Iron that gets you another $40 off, making it like $66 - shipped..
Old Feb 14, 2012 | 09:32 AM
  #346
ynots's Avatar
ynots
Originally Posted by SC-Longhair
If you have to straddle the bike to stand it up to fit the jack underneath, you're doing it wrong.
I have tried that procedure *ONCE* (straddle bike, stand it up straight and roll the jack underneath). What an awkward recipe for disaster that seemed to be.
If you're bike is lowered, then that is one of the prices you pay for having a low sitting bike. Space permitting, a lift table may be a better choice for someone in this situation.
Watch the original video again. I did not have to stand the bike up. I rolled the jack under the bike. The jack bumped the jiffy stand. I pulled it back just a *hair*. Performed a quick check of position and began jacking it up. I assure you there was no trickery involved.
I have always noticed that the bike will sort of self-center on the rails if I'm fairly close on the backend where the irregular frame is cut to begin the dropdown for the oil pan. It'll just slip into the jack a little.
Just my opinion.
Straddled the bike while trying to roll a jack under it is a great recipe for disaster. The first thing that popped into my mind was Darwin award Lol
Glad to hear you didn't learn a lesson the hard way longhair.
I use a wheel chock. Its not necessary, but it make it easier to position the jack, especially when adding shims and for those who are uninhibited.
My bike has been up and down many times with and without a wheel chock.
My shocks are longer than stock so my bike leans more on jiffy stand... and corners ;o)
Old Feb 14, 2012 | 10:06 AM
  #347
dreamer65's Avatar
dreamer65
I had the expenive sears yellow jack what a POS it was scared the crap out of me the 2 or 3 times I used it, sold it for a 100.00 bucks
I got a HF yellow jack for 59.99 with the coupon did the mod works great when I jack up the dyna it easy and very stable.
once again thanks Vic for the mod info, also good to see you back on the fourm
Old Feb 14, 2012 | 11:04 AM
  #348
SC-Longhair
Wow, you really thought that one out. I guess if I had some uni-bar and angle iron lying around that'd work out cheaply.
Old Feb 14, 2012 | 11:07 AM
  #349
SC-Longhair
That was in the early days with my jack and the adapters. Once was enough for me. Tequilla on the other hand was a different story.
Old Feb 14, 2012 | 12:23 PM
  #350
ynots's Avatar
ynots
Oh ya.... good ole Tequilla! I dont even want to talk about some of the adventures I've had Lol Great job putting together your video on the jack mod
